Page 1 of 1
Rotating brake lever attachment on handlebar 2005 R1200RT
Posted: Thu Feb 01, 2018 8:32 pm
by jackronner
I want to slightly rotate the brake lever up about 1/2 inch.  Before I start messing with it, will I find that the brake lever unit is fixed in place on the bar, by a ridge fitting into the unit, etc.,  and therefore incapable of being rotated?  Also, can I alternatively loosen the main screw of the bar tube (at the inner end) and then just rotate the tube itself?  Will I have to withdraw the tube completely first (I anticipate that the end will be ridged to prevent rotation around its axis)?  Will removing it necessitate removing the various cables?  I kind of miss the old-fashioned bars;  it would have been much easier with them.  Thanks.
Re: Rotating brake lever attachment on handlebar 2005 R1200RT
Posted: Thu Feb 01, 2018 9:04 pm
by temesvar
I have a 2008 RT and it should be very much same as yours. Have altered the bars, so have all the controllers open right now.
Yes, you can rotate the assembly either way you like, it is not locked in a certain position on the tube, as I thought it may be. However will
not be able to rotate the tube. At least I couldn't hammer it out, it is press fit! So you can do it easy enough by opening the controller set,
turn it to your desired position, retighten and off you go. I imagine would like to do the same on the clutch side. If need any help or pictures,
have everything apart right now. I should get the bars back and re install them by the end of the week.
Posted: Thu Feb 01, 2018 11:02 pm
by jackronner
Thanks for the help.  I certainly found the right guy out there.
