Page 1 of 1
Topbox query.
Posted: Sat Jul 14, 2018 11:07 am
by milleplod
I've just fitted, for the first time, my small (28ltr?) BMW topbox to the RT - I'd previously used it a lot on my 1200ST. There seems to be some 'play' once fitted, a slight side-to-side movement that was never there when on the ST. I can't see that there's anything that might be worn on the RT's mounting plate, and I don't think its going to come off! - anyone else got this? Any observations at all?
Pete
Re: Topbox query.
Posted: Sun Jul 15, 2018 8:59 am
by beemerboy9
I wouldn't worry about it. My 49-litre top-box has some play.
Just shim it with some tape/rubber bumps stops/WHY - otherwise it will rattle over bumps and drive you nuts.
Regards,
John
Re: Topbox query.
Posted: Sun Jul 15, 2018 9:30 am
by milleplod
Thanks for the reply John, appreciated.
Yep, self-adhesive foam at the ready.....  :)
Pete
Re: Topbox query.
Posted: Sun Jul 15, 2018 9:38 am
by beemerboy9
Hi,
Try put some strong tape over the foam to hold it in place.
John
Re: Topbox query.
Posted: Sun Jul 15, 2018 9:52 am
by milleplod
I've just found some 1/2" Gorilla tape in the garage - should do nicely!
Pete
Re: Topbox query.
Posted: Thu Jul 26, 2018 7:33 pm
by slparry
milleplod wrote: I've just fitted, for the first time, my small (28ltr?) BMW topbox to the RT - I'd previously used it a lot on my 1200ST. There seems to be some 'play' once fitted, a slight side-to-side movement that was never there when on the ST. I can't see that there's anything that might be worn on the RT's mounting plate, and I don't think its going to come off! - anyone else got this? Any observations at all?
Pete
Pete, I had that once, turned out I'd lost one of the rubber feet
77438527603
Part 3 in this image
https://www.realoem.com/bmw/enUS/showpa ... 7438527603
