I was thinking of bypassing the Canbus altogether and using one of these.
http://www.easternbeaver.com/Main/Wirin ... ealed.html
Just need a switchable power source for relay.
Aux Sat Nav Connection
Re: Aux Sat Nav Connection
Stratman wrote: I've never found it as complicated as many seem to make it. Ho hum.
So let us into your secret.
easiest power supply that goes on and off with the ignition that is NOT controlled by CANBUS is the feed to the aux power socket
its easy to splice into the wires underneath, just take the panel off
Well yes but I left a USB charger socket in mine once and it flattened the battery.
mm... on my 2007 RT the power to the aux socket is cut with the ignition
i can't speak for later models, maybe on later models this power is controlled by the CANBUS system, hence if anything is plugged into it and drawing any power (however small), the CANBUS system will continue to supply it.
Thanks for links. My model aux socket must be Canbus controller because I use a Canbus friendly charger to charge battery through this socket.
i would plug it into the Canbus socket and see how you get on. some people find this ok, others don't.
Levisp wrote:
Not on mine. Below is a pic of my BMW Garmin Nav lead. The bigger white plug is the one that goes into the bikes harness. The smaller one with black tape over it is just spare. On the bike this spare plug is just zipped tied to the harness. I put insulating tape over it to stop moisture getting into it. Its this plug the spare one that the Nippy's additional power lead plugs into.
The smaller of the cables is in fact a connection for an additional antenna for the unit. Never known it to be used on the latest Navigators. It has nothing to do with powering the Navigator.
Every 1200 RT has Canbus wireing with the later ones, I think about 2013 onwards being Limbus. If you buy anything that is not BMW and plug it into an accessory socket there is always the danger the system will stay open when you switch off. If it didn’t do that you would not be able to use a battery charger. USB adaptors are the worse offenders. It’s easy to know if something keeps it open. Switch off and listen carefully for about 40 seconds. Hear a click. It’s off.
OK so what your saying is Nippy's aux plug / lead plugs into bikes harness and replaces the BMW Garmin part altogether.
Maybe OP could verify this as he did it.
I askd a Tech at dealers the best place to power a camera through the ignition. Mne has the Nav. Was tld use the fuse under the seat and piggy back the one that goes through ignition. Can the your nav not use this?
Beagle wrote: I askd a Tech at dealers the best place to power a camera through the ignition. Mne has the Nav. Was tld use the fuse under the seat and piggy back the one that goes through ignition. Can the your nav not use this?
Why would you when the bike has a dedicated socket for the GPS. I had an Autocom on mine and that was connected via the fuse next to the battery box.
RTman10 wrote:
Why would you when the bike has a dedicated socket for the GPS. I had an Auykvom on mine and that was connected via the fuse next to the battery box.
Apologies, I thought some were having problems with that.
