Page 1 of 1
Starting problem
Posted: Sun Aug 19, 2018 3:28 am
by viator
HiI'm aware of and have read all the starting problem discussions here, but mine is a bit different ;-)
2007 R1200RT-P 99k km
Symptom:Press start button 1st time and it is like a flat battery - just grinds to a halt. (No strange sounds like grinding, clanking etc.)
Wait a few seconds and in most cases, it cranks well and starts normal. Every now and then, it takes a few goes - again like battery is flat.
Observations:
  • Hot or cold engine - no difference
  • Weather - Tropics! Australia HOT, damn hot
  • New Fullriver HC20 battery - cable connectors clean and good connection
  • Swapped starter relay for another (second hand one I had from one of my previous BMW cars - same model) - no change
Any ideas?
Thank you very much.
Re: Starting problem
Posted: Sun Aug 19, 2018 7:20 am
by viator
Just some more info and update:
  • Lubricated the side stand - silicone spray
  • Lubricated and cleaned the starter handlebar switch - silicone spray
  • Adjusted the valves and endplay on rocker arms - they were pretty much on specifications anyway
and...
started 1st few times immediately
took it for a drive.
Same problem  :'(
Posted: Sun Aug 19, 2018 5:11 pm
by B787MECH
Replace battery cables for new high capacity ones and recheck battery earth would be my suggestion. Hope this helps.
Posted: Sun Aug 19, 2018 6:57 pm
by percy
Faulty starter motor?
This sounds pretty similar to a problem I had on my old 1100 RT.
Posted: Mon Aug 20, 2018 7:06 am
by mcwhirtj
I'm also voting for starter motor, fwiw.
Posted: Tue Aug 21, 2018 12:13 pm
by viator
Thank you for all the replies.Strangely enough, it has started 1st time the last two days on every occasion. Could the valve adjustment have had such a big influence? They were very close to or on spec, before I adjusted them again.
If it starts failing again, I'll change the cables and then last resort import the expensive new starter to OZ.Thanks again.
