Map update
- Been liked: 379 times
Re: Map update
When I try to install the map update, GE prompts me to select a region because the internal (device) storage space it not sufficient for the size of the full EU maps. I'm no longer given the option to install full EU to the SD card. I have to select the most appropriate region for a particular trip. Any additional coverage needs to be selected from either MapSource or MapInstall (Basecamp) and installed manually to the SD card.
Re: Map update
This is what GE prompts me to do if I wish to make an update or change the current (UK & Ireland) maps installed on my device.
- Stu
- Administrator
- Has liked: 540 times
- Been liked: 487 times
Re: Map update
Lots of useful information on here for the zumo's, BMW navigators, basecamp and garmin express
https://www.zumouserforums.co.uk/
Some very knowledgeable people too
- Bike Model and Year: 2022 R1250RT
Re: Map update
David,
Been putting full EU maps on SD card for some time now. I took some friends to visit Colditz/Dresden a few years ago, and quickly 'popped' across the Czech border as another country visited. Unfortunately I didn't have the right maps at that point and fell off the edge of the world..........
Steve P
Used this a few times sussamb is very knowledgeable and helpful.sakm wrote:Lots of useful information on here for the zumo's, BMW navigators, basecamp and garmin express
Steve P
Re: Map update
How have you been putting full EU maps on an SD card.paynes1 wrote:Been putting full EU maps on SD card for some time now.
This is what full EU should look like, inc. Czech.
Re: Map update
This problem of now having to select a region first occurred with the 2021.20 map update in April 2021.
I posted on the Zumo Users Forum but didn't get a satisfactory answer, CN EU 2021.20 NT - Zumo User Forums
Re: Map update
Found this screen shot of what GE used to offer if the maps would not fit on the device's internal memory.
Previously, I'd select "use a memory card" and install full EU.
This is the option which GE is no longer offering and I have to select a region to install to the device only.
Re: Map update
I've posted this on the Zumo Users Forum, CN Europe NT 2022.10 - Zumo User Forums will be interesting to see what is any replies I get.
Have also sent an email to Garmin UK.
Re: Map update
David,I had the issue of the maps not fitting on the device some time ago so installed a SD card and put them all on that. Now it just replaces them on the card although from memory I think GE gives me the option of changing the region. I don't bother, I use the card for maps and store my music on the device.
Re: Map update
Hi Steve, how do you install the maps on an SD card and is it full EU or just a particular selected region.
Re: Map update
This is the reply I got from Garmin.David. wrote:Have also sent an email to Garmin UK.
"This would be due to a internal space issue with your device, as the full EU maps are arrowed 19GB in size.
As this is greater than lots of our older sat navs storage space a SD card would be needed to install these.
With mapinstall this allows the maps to be spread between the internal storage and the SD card in the device."
Re: Map update
Was this for a BMW Nav., I regularly check Garmin Express and 2023.10 is now available for my Garmin Zumo 660.7vwh wrote:Map update 2023.10.
