Oxford Heated vest controller (HV727)
Sprintgull
Post by Sprintgull »
Evening All,
Bit of an issue (slightly off topic): I've got an Oxford/Keis heated vest.  Well I say heated..... not any more.
Last week the cable containing the controller snapped at the plug.  Anyone else had this problem and found a solution to this as there do not seem to be any available anywhere.
Cheers.
Been liked: 280 times
Re: Oxford Heated vest controller (HV727)
Sprintgull wrote:There do not seem to be any available anywhere.
Is this what's required, Control Unit HV727 Inox Vest, https://www.mandp.co.uk/control-unit-hv ... -vest.html
Levisp
Post by Levisp »
Don't quite understand the issue maybe a pic would help. If its an Oxford vest made by Keis could you use a Keis controller. I use a Keis vest and its the best bit of winter kit I have so I can understand you want to get yours working again. Post a pic.
beemerboy9
Been liked: 16 times
Post by beemerboy9 »
David. wrote: Is this what's required, Control Unit HV727 Inox Vest, https://www.mandp.co.uk/control-unit-hv727-inox-vest.html
That controller is identical to the one used on the Ventureheat MC10 Heated Vest available on Amazon.
I have a Ventureheat vest (not that model) which mates perfectly into a Gerbing plug. Make sure that whatever controller you buy is matched to the power draw of the vest.
Good luck,
John
Sprintgull wrote:I've got an Oxford/Keis heated vest. Last week the cable containing the controller snapped at the plug. Found a solution to this as there do not seem to be any available anywhere.
The Keis Light Weight Controller looks very similar to the Oxford one, https://www.keisapparel.co.uk/product/k ... ontroller/
Keis do adaptor cables, https://www.keisapparel.co.uk/product-c ... es/page/3/, looks like there could be marginal plug/socket size differences between Keis and other makes.
Sprintgull
Thanks for the guidance guys.
I was being a bit thick and of course the alternate brand is Inox not Keis!  M and P are sold out as are a few others I tried, but I think I've found one.  The Ventureheat unit looks really similar though, will bear that in mind if I get let down again.
Thanks again
Kevin
