Page 1 of 1
Intercom recommendations
Posted: Sat May 18, 2019 7:05 pm
by daverj
I’m currently using a Schuberth helmet with the built in Cardo system. I’m having lots of problems with pairing to bike and Nav system and when I finally get it working as it should they soon stop working if I stop and disconnect. So any recommendations mainly used for nav instructions and listening to music. TIA
Re: Intercom recommendations
Posted: Sat May 18, 2019 7:19 pm
by BoB21
No radio use interphone sport easy to work. Music on memory card.
Posted: Sat May 18, 2019 9:30 pm
by daverj
Is your music on the nav or via the bikes audio?
Posted: Sat May 18, 2019 10:05 pm
by Sleuth
i used to use a Cardo system - it was such a success I got my money back and went with Sena (SMH10)! be
After many years with a Sena intercom working as it should, I am now considering replacing it.  My choice is quite simple Bloothtooth (Sena) or go old school - Wired (Autocom)
There are advantages & disadvantages for each.
Currently I am favouring the wired set-up.
If you are thinking of going Bluetooth - I would recommend Sena.
Best regards
Sleuth
Posted: Sun May 19, 2019 1:36 pm
by Casbar
I have had a Cardo Packtalk for 5 years, been fautless, brilliant bit of kit. I did have a Sena 20s but it was rubbish, think they released that model before it was really ready, probably ok now. But returned it, got my money back and bought the Packtalk. Best decision I made. Moved away from wired years ago, after my pillion cable to the helmet came undone on the motorway and the cable wrapped around my rear sprocket. That was the end of wired for me. The latest BT kit is pretty good now. Sena or Cardo both have their fans and both have had their issues.
Posted: Wed May 22, 2019 7:45 pm
by daverj
I went for the Interphone (urban) intercom. Connected to phone and bike Audio system with no problems, just need to try it on the road to see how easy it is to get on with. Thanks for everyone’s input.
Posted: Wed May 22, 2019 7:59 pm
by BoB21
if you have music on card in nav and cant hear anything but it showing as playing on nav. switch off intercom and switch back on and push play on nav. Long story !!! hope that helps in advance pm if have problem.
Posted: Wed May 22, 2019 11:17 pm
by daverj
Will look out for that on my test run, thanks
Posted: Thu May 23, 2019 9:51 am
by DavidMcK
Best regards
Sleuth
Hi Sleuth, I have used Autocom since 2005, but, I have now moved to the Sena SRL with the Neotech II helmet.
It is superb and I would not go back to a wired system.
Thought I would pass this on.
Posted: Thu May 23, 2019 10:50 am
by STeinar
I started with my own construction and build of Intercom - Then ended on several versions of Autocom. Some slightly modified by me.
Autocom - do work grate for the price
Then ended up on AKE - systems at https://shop.ake-electronic.com/  - works grate - and super sound quality. - The best wired system I have ever owned.
Then I would like to try some BT units - First the old BMW 2.1 in my BMW-6 helmet - did not really like it - no good sound from it
Then I bought a Schuberth C4 with integrated Sena BT - with remote control and everything.
Well I never got really friend with the C4 - not hing really wrong with it, but not "mine"
And the Sena BT in it - did not really work for me. Missing Sound quality, and general usage - no - not really
Then got me a BMW 7 and the new BT system - and this helmet soutes me better - and sorry to say, but the BT just works
Yes - a bit of old technology in it - but it just works - after two months of usage - not a single hiccup
I had to pad out the speakers a bit to soute my ears a bit better - and sound - well not HiFi - but works good for me
So BMW-7 - and BMW BT - is the best option for me - (for now :-) )
STeinar
Posted: Thu May 23, 2019 12:42 pm
by LAF
STeinar wrote: I started with my own construction and build of Intercom - Then ended on several versions of Autocom. Some slightly modified by me.
STeinar
So who do you think makes the BMW helmet and the BT module in it?
Posted: Thu May 23, 2019 1:20 pm
by STeinar
LAF wrote: So who do you think makes the BMW helmet and the BT module in it?
Well - the helmet I do not know. Before there was an label inside - telling the produsent - but not any longer ...
The BT is made by Siemens - Germany.  It says Siemens all over the module.
I have seen someone writing on the web - that it was Sena, But at least on my BT - it says Siemens.  Same as the one for the System-6
It looks somewhat similar to the one for the System-6, but slightly different.  Same battery btw.
The buttons on the side of the helmet - is all different to System-6
Steinar
