Hi
I recently purchased an RT1250, after decades of riding my VFRs, and am impressed with the comfort.
However, as I have a new TomTom satnav, I would like to use it with the RT. In this connection, is there a live feed connection that I can tap into, to power the TomTom?
Tony.
Switched live feed enquiry
- exportman
- Has liked: 10 times
- Been liked: 47 times
Re: Switched live feed enquiry
Hi
I have the 2016 model but used a feed from the auxiliary socket on the right hand faring cover. I have mounted my tomtom where the Garmin unit mounts. I removed the Garmin cradle and mounted the tomtom device using the same 4 threaded holes, but from the rear, so I had to remove the screen and the top panel
Picture shown is for the 2015 tomtom but my rider 550 is mounted in the same place. I have used the feed from the aix socket as a switched feed for a relay which then controls the power from the battery to a fuse box to several accessories
Hi Exportman
Many thanks for your reply. Is there a wiring diagram available for the RT1250, to facilitate me identifying the auxiliary socket?
Or is there a photograph available of this socket?
Many thanks.
Tony.
Many thanks.
Tony.
