Thanks for that.
Rear PowerSocket
Rear PowerSocket
I believe, if I read the wiring diagram for my 2009 R1200RT correctly, the wire to both the front and rear sockets is 1mm (18 AWG):Shakleton wrote: There is a power socket nestled under the rear seat for the pillion.
Can anyone inform me as to what current it draws please? (the manual is silent).
My wife has a pair of heated Gerbing gloves and a heated Gilet (SHMBO likes to be warm). We have failed to get these to work so I am guessing it is like the front power socket which has a limited power draw?
I have wired an accessory socket direct to the battery for an air pump. Can I retire the pillion socket direct to the battery or do I have to run another one separately (Canbus etc)
Many thanks for any help, insight and wisdom
This implies by the DC ampacity tables for wire that current should be limited to 12.2A for a 3-foot cable, and 9.1A for 4-foot cable, hence the 10A total limit for the sockets since both share the same positive wire (terminal 4 on the ZCU)...
So the solution is as others have suggested...install a connection to the battery protected by a fuse (and triggered with an accessory-controlled relay), or install a Hex ezCan.
Last edited by rangemaster728 on Mon Jun 10, 2019 3:42 pm, edited 1 time in total.
Re: Rear PowerSocket
Here's an excellent explanation of the use of fuse size and wire size with Powerlet sockets.
https://www.powerlet.com/learningCenter/fuseSizing
