Hi all
I can’t find the trip to zero my trip before start of a journey. When I read manual, it says it does it automatically, zeroing at each stop. Doh
But I can’t see anywhere the trip.
Trip on computer
- Been liked: 478 times
Re: Trip on computer
The LHS button is the control for the odometer, (DIST).
Press the button to select, Trip 1, Trip 2 or Total Dist.
Select the desired tripmeter, press & hold down the button until the tripmeter reading has reset.
The instructions are correct.
Press left button to select trip then press and hold it should then zero.
The info button?? I am sure I have pressed it a hundred times, but doesn’t pop up trip. Will take another look, cheers lads.
Motorbiking is a life, not a hobby. Ride with Pride.
No, the button on the dash, below the speedo, as shown in the photo above.Davef1uk wrote:The info button?
Not the INFO button on the LHS handlebar switch.
Doh. What a numpty. Yeah, found it. Could not see the blighters lol. Cheers
