Page 1 of 2
Crud Catcher
Posted: Fri Dec 04, 2020 4:59 pm
by hammo
Hi Guys
          Any tips on the best crud catcher for a 1250RT ?
Re: Crud Catcher
Posted: Fri Dec 04, 2020 5:09 pm
by Gavj
I made one... can send dims if you are able to knock up one yourself... spacers are a bit awkward if you dont have a lathe, long bolts will need to be bought.
Re: Crud Catcher
Posted: Sat Dec 05, 2020 3:08 pm
by Gavj
Dims of my one if you want to knock one up....
Re: Crud Catcher
Posted: Sat Dec 05, 2020 3:56 pm
by David.
Some crud catchers require the front deflector to be removed, others or DIY ones don't.
Nippy Normans list a Cymarc version which requires the front deflector to be removed,
https://www.nippynormans.com/camping-tr ... -onr1250rt
Cymarc themselves show a 1250 version with the front deflector fitted,
https://www.cymarcbikeparts.co.uk/r1250 ... 1116-p.asp
Re: Crud Catcher
Posted: Sat Dec 05, 2020 6:26 pm
by David.
Looks like Wunderlich offer two versions which both work with the front deflector fitted.
https://www.wunderlich.de/shop/en/bmw-r ... 2-002.html
https://www.wunderlich.de/shop/en/bmw-r ... 0-100.html
Re: Crud Catcher
Posted: Sat Dec 05, 2020 6:41 pm
by David.
Re: Crud Catcher
Posted: Sun Dec 06, 2020 5:25 pm
by bandytales
Wow. I am not normally a fan of Wunderlich stuff, but they have made a great job of this black one.
Re: Crud Catcher
Posted: Sun Dec 06, 2020 5:47 pm
by TJRL
My thoughts exactly, not at all impressed with Wunderlich stuff in the past, but this protective plate is good, which is why I fitted one to my R1250RT before it had done 20 miles!!
Re: Crud Catcher
Posted: Thu Dec 17, 2020 7:19 pm
by wethead
School on this please....
...cause I don't see no sene on putting a plate infront ot the engine block so that now you have to clean the plate.
Why not just install a fender extender; there is probably a bunch in the market
Re: Crud Catcher
Posted: Thu Dec 17, 2020 8:05 pm
by Gavj
This is with a fender extender  :o
Re: Crud Catcher
Posted: Fri Dec 18, 2020 4:53 pm
by bighopper
I just got the exact same unit look from AliExpress for $45cdn shipped to Canada from China.
Re: Crud Catcher
Posted: Fri Dec 18, 2020 5:25 pm
by speedy
Evotech Performance makes a nice looking one as well.  Don't own one, but was thinking about it...
[size=2px]https://evotech-performance.com/collect ... 01-to-2018[/size]
Re: Crud Catcher
Posted: Fri Dec 18, 2020 5:41 pm
by Casbar
If you bolt an engine protector on, doesn't that just trap all the crap behind it? The purpose of an engine protector is the same as a sump guard to stop something damaging the engine. If you just want to keep debris from marking the casing, then a fender extender does the job. But if you want to ride the bike up tracks then you probably need one. Had a fender extender on my 2014 for 4 years and one on my 1250 for the last year or so and the engine still looks fine. Got mine from Nippy Normans. fits without drilling.
Re: Crud Catcher
Posted: Fri Dec 18, 2020 8:06 pm
by wethead
Casbar wrote: If you bolt an engine protector on, doesn't that just trap all the crap behind it? The purpose of an engine protector is the same as a sump guard to stop something damaging the engine. If you just want to keep debris from marking the casing, then a fender extender does the job. But if you want to ride the bike up tracks then you probably need one. Had a fender extender on my 2014 for 4 years and one on my 1250 for the last year or so and the engine still looks fine. Got mine from Nippy Normans. fits without drilling.
Casbar, you are spoiling the joy of buying useless things for one's beloved motorcycle...be
Re: Crud Catcher
Posted: Sat Dec 19, 2020 8:02 pm
by TJRL
I have fitted front (and rear) fender extenders to my; R1150RT, R1200RT (air cooled),2015 & 2018 R1200RTs (water cooled) and whilst definitely worth fitting I can tell you they do not stop (a lot of!) crud hitting the large flat front of the engine. Over time stones etc will damage the finish of this large exposed area. I found the original smaller SS "crud catchers" helped but did not protect the whole of the engine front.
These latest plastic crud catchers protect the whole area and because they also stand off on spacers (as did the older SS ones) there is no danger of crud getting caught or stuck behind it.
If there is any deterioration to the finish of the engine front with this fitted, there will be no room for BMW to say "normal wear and tear" damage like they have tried in the past!
My experience of 8k "all year round" miles per annum over the years tells me that a front fender extender AND one of these new full size crud catchers will give the best level of protection and preserve the finish of the front plate. The irony is that day to day I will not see the pristine finish until I remove the crud catcher just prior to selling the bike!!
Just my 2d worth - YMMV.
