Interesting and Entertaining R90S Build.
Our Gee
Been liked: 33 times
Post by Our Gee »
I came across this Utube Video of an R90S being built from new parts at Max BMW in the USA.
https://www.youtube.com/watch?v=cmVBNSjjrRo
Our Gee
Re: Interesting and Entertaining R90S Build.
Post by Our Gee »
76 Views to date and no one has anything to say. :grave:
RTs4me
Has liked: 6 times
Been liked: 19 times
Post by RTs4me »
I've just finished watching it! Very interesting. Thanks for posting.
Good to see such thorough bike preparation. Much better than some of the 'restoration' videos.
Airheads are not my thing, but I recognise the heritage that's got us to where we are today.
Has liked: 489 times
Been liked: 408 times
I'm rather surprised by the absence of anti-seize compound on any of the various nuts and bolts that may require removal at later date.
When I got my used 2018 model I applied coppaslip to every fairing bolt I could find and unfasten, and some of them were a bit creaky to remove... but I guess that's real world as opposed to a showroom piece, although they did take it out for a test ride in the snow and slush, damned if I would!
Our Gee
Post by Our Gee »
Interesting observation Steve as I also am a fan of "Careful" use of thread lube / anti seize such as Coppaslip. However I can't recall ever coming across evidence of anti seize when dismantling a "threaded" factory assembled connection.  As far as I know the vast majority of Torque values are given for assembly and tightening of "Dry" threads. The application of an Anti Seize / Thread Lube requires a decrease
to the given Torque value of something like 25% depending on the medium used. Tightening a lubricated threaded assembly to a value given for "dry" assembly risks over tightening and the possibility of component failure.
Been liked: 480 times
One thing BMW do like using a lot of is screw lock to stop things falling apart.
Levisp
Post by Levisp »
Our Gee wrote: Interesting observation Steve as I also am a fan of "Careful" use of thread lube / anti seize such as Coppaslip. However I can't recall ever coming across evidence of anti seize when dismantling a "threaded" factory assembled connection.  As far as I know the vast majority of Torque values are given for assembly and tightening of "Dry" threads. The application of an Anti Seize / Thread Lube requires a decrease
Agree regards dry threads and torque values. I prefer to use ACF50 Block Grease on threads and generally reduce the torque by 10% and round down. So far never had an issue.
I’ve only recently discovered the ACF grease which I’m now using in preference to Copperslip, and fully also agree/accept your point of decreasing the torque values when it’s applied too.
