BMW R1200RT Cam alignment tools
sakm
Has liked: 233 times
Been liked: 184 times
Re: BMW R1200RT Cam alignment tools
Post by sakm »
Doctor T wrote: Mon Jan 09, 2023 1:46 pm Not clear what these tools are for? Can you explain what they are used to fix? :?
Starting from the top is the tool for locking the cylinders in either TDC or BDC
Middle is the cam chain tensioning tool which is used in conjunction with the bottom one which is the alignment jig
The alignment jig is used for locking the cams in time with each other after you have found TDC and tensioned the cam chain to the correct spec :thumb:
Has liked: 339 times
Been liked: 98 times
Got it now. Looks like an expensive bit of kit.
sakm
Post by sakm »
Doctor T wrote: Mon Jan 09, 2023 7:40 pm Got it now. Looks like an expensive bit of kit.
Can't remember how much it was to be honest! but it certainly wasn't cheap
But it was cheaper than the dealer doing the job ;)
sakm
Post by sakm »
This is what I paid
1. Alignment pin (83302327790), Quantity: 1, Price: 67,22
2. Timing chain tensioner assembly (83300444292), Quantity: 1, Price: 169,67
3. Sleeve (83302339885), Quantity: 1, Price: 8,51
4. Alignment jig (83302327796), Quantity: 1, Price: 27,30
Thats all in Euro's plus 54 Euro's postage
307,70 in total
Has liked: 108 times
Been liked: 13 times
Was the cam timing out ?.
sakm
Post by sakm »
Panman40 wrote: Tue Jan 10, 2023 4:44 pm Was the cam timing out ?.
Yes on both sides
Only a touch but its enough
These bikes are known for them to go slightly out of time
It's probably due to the cam chain wearing or stretching slightly with use
I’ve had the tools on order since late December, it’s now going to be April before the 1250 cam jig and the cam chain tensioner are available! :shock:
Been liked: 239 times
Panman40 wrote: Sun Feb 05, 2023 8:04 amI’ve had the tools on order since late December, it’s now going to be April before the 1250 cam jig and the cam chain tensioner are available.
Where have the tools been ordered from.
KFM say "probably available from Mar 17, 2023", https://www.kfm-motorraeder.de/item/bmw-83302467268
A part number search came up with this, https://www.topsalesprint.online/detail ... mjpho.html
sxc
Post by sxc »
David. wrote: Sun Mar 05, 2023 10:28 am Where have the tools been ordered from.
Cam alignment tool (jig) for R1200 versus R1250 is different, the supplier links are appreciated but appear to be for R1250, the first link is legit, all vendors are guessing at this time, the second link seems like a scam, try calling and see for yourself...this thread BTW is for R1200, just saying.
Re: Cam tools
sxc wrote: Thu Oct 06, 2022 5:02 amShift-head cam alignment jig available w/free shipping...ordered from here...https://beemerparts.com/product/bmw-ali ... ace800f676
sxc wrote: Mon Mar 06, 2023 3:56 pmThis thread BTW is for R1200, just saying.
Does the Cam shift engine use shims?
Doctor T wrote: Mon Mar 06, 2023 4:40 pmDoes the Cam shift engine use shims.
Yes, see #7, called Adjusting Plate, available in different thicknesses.
