I am looking for a plug
Has liked: 12 times
Been liked: 7 times
I am looking  for the 10 pin round connector (red indicator inside) that connects to the top case wiring harness for a  2017  R1200RT [/font][/size]The wiring harness part number is 61128354792. This harness fits multiple 1200 and 1600 bikes, but it sells for @$300.  All I need is the connector. Does anyone know of a source or part number for this barrel connector?[/size]
The pictures show what the connector would plug in to
sakm
Has liked: 238 times
Been liked: 186 times
Re: I am looking for a plug
Post by sakm »
Simply put! you cannot buy this part separately! it comes with the top box
You can't even buy the wiring loom!
I have searched high and low in the past as I was positive I had seen them for sale but you just cannot find it at all
Unless the dealers can order it
michaelc2710
Has liked: 5 times
Been liked: 6 times
Post by michaelc2710 »
Your can buy normal 5 pin connectors and cut the other round plug off, keep it safe and solder back on if selling the bike
Has liked: 355 times
Been liked: 99 times
Try going to a vehicle breaker. All BMW cars use the same plug and socket as our bikes. With a pair of wire cutters, you should be able to remove the plug/socket with enough wires attached.
Has liked: 12 times
Been liked: 7 times
Thanks, I am not too far from one. :thumb:
