Page 1 of 1
Settling in.....
Posted: Thu Aug 25, 2022 7:18 pm
by sakm
Well I think I am almost finished with all the background work!
I have installed a couple of different themes so if you don't like the default one you can easily change it via your user control panel
I am going to change the smilies as I think they are shocking to be honest! probably go with the stock ones and add a few other basic ones to compliment them
I have figured out a way to make images work but it means manually editing the database and to do that for over 6k images is just suicide! So if its one of your posts missing images then feel free to edit the post and add the images back if you have them.
Avatars haven't transferred over either so feel free to upload a new one or delete the one thats supposed to be there
you may see a few new features available to you so feel free to try them out or ask questions about them
I am also open to suggestions and if I can accommodate I will do
Re: Settling in.....
Posted: Thu Aug 25, 2022 9:04 pm
by burridge01
Is it possible for me to change the information from the right back to the left(username, avertar etc)
Thanks.
Posted: Thu Aug 25, 2022 9:36 pm
by sakm
burridge01 wrote: Thu Aug 25, 2022 9:04 pm Is it possible for me to change the information from the right back to the left(username, avertar etc)
Thanks.
I know I like a challenge! I will see what I can do as normally this sort of thing would affect all accounts and require a lot of major changes
I do prefer profile on the left myself!
Posted: Fri Aug 26, 2022 7:19 am
by burridge01
Cheers Sakm.
Posted: Fri Aug 26, 2022 7:49 pm
by Sharkfighter
Sakm you've done a brilliant job, I'm getting used to the different layout and navigating my way around. :)
Posted: Fri Aug 26, 2022 8:20 pm
by sakm
Sharkfighter wrote: Fri Aug 26, 2022 7:49 pm Sakm you've done a brilliant job, I'm getting used to the different layout and navigating my way around. :)
Thanks
I know things are a little different but they won't take too long to figure out where everything is
Posted: Fri Aug 26, 2022 9:10 pm
by thwak
Thanks for taking on such a difficult task and doing it so well and with patience!
Posted: Sat Aug 27, 2022 8:14 am
by sakm
Thanks.
Sorted
Go to user control panel click board preferences then go to Edit display options and look for Post profile side
This only has an affect on full screen mode and not when viewing on a mobile phone :thumb:
