The new to me 2018 RT has a few UV damaged area of black plastic. Some parts will restore with heat, other areas which are a different type of plastic wont. Is there a method for perminently getting it to look black again?
Cheers
Restoring black plastic
- Bike Model and Year: R1200RT 2018
- Has liked: 15 times
- Been liked: 4 times
- Been liked: 478 times
Re: Restoring black plastic
Doesn't look like it, https://drivedetailed.com/how-to-perman ... -easy-fix/Dreadnought wrote: ↑Thu Nov 03, 2022 6:43 pm Is there a method for permanently getting it to look black again?
- Been liked: 399 times
I've used Wùrth on loads of stuff. Brings plastic back to black lovely.It will last a long time and just top it up when needed. 1 tube did my Mwb Sprinters bumpers front and back and the side trim both sides,2 coats . It's not cheap but you will get a good result and it goes a long way.
https://www.ebay.co.uk/p/1147551604
Word of caution, do not get it on any paintwork, it is a bugger to get off
- Been liked: 25 times
Gtechniq C4 has worked for me. A small amount goes a long way.
- Has liked: 1440 times
- Been liked: 409 times
A heat gun on low temp will turn faded black to look like new. A temp fix is WD40 and alike
