Quick Shifter
Dreadnought
Has liked: 14 times
Been liked: 4 times
Quick Shifter
Post by Dreadnought »
How do you determine if a quick shifter is fitted, it was easy to tell on mn my Triumph as it had an ignition cut out in the shifter mechanism?
Been liked: 240 times
Re: Quick Shifter
Look at the gearshift shaft. In the following diagram, assembly 11 replaces item 1 if Gear Shift Assist is fitted.
Dreadnought
Has liked: 14 times
Been liked: 4 times
Re: Quick Shifter
David. wrote: Wed Nov 30, 2022 3:18 pm Look at the gearshift shaft. In the following diagram, assembly 11 replaces item 1 if Gear Shift Assist is fitted.
Many thanks
