How to remove instrument cluster R1200RT/RT1250RT
GvG
Post by GvG »
Does somebody know how to remove an instrumentcluster of a R1200RT LC/R1250RT, can you just pull it towards you (and pops out the rubber grommets) without removing any bodywork, or do you have to remove a lot of bodywork?
https://www.realoem.com/bmw/enUS/showpa ... Id=62_0598
Has liked: 622 times
Been liked: 601 times
Re: How to remove instrument cluster R1200RT/RT1250RT
I have recently had all the front bodywork off and there is 3 clips that hold the cluster in place
Unfortunately I can't confirm if you need all the body work off though!
I would remove the sat nav cowling and see if you can get to them from there
GvG
Post by GvG »
Thanks. Well, if I look at the Realoem picture, It looks like the instrument cluster is only popped into those 3 rubber grommets, but that's likely to easy ;) Probably some bodywork has to be removed.......
According to this you don't need to remove anything other than what I said above
Cluster removal.pdf
(850.76 KiB) Downloaded 926 times
GvG
Post by GvG »
Thanks again my friend :thumb:
