My R1250RT has developed a starting issue, going to book it in to be looked at but before I do would welcome any collective wisdom.
Turning on with the keyless button then starter button starting as normal, cold or hot.
Turn the bike off on the kill switch and attempt to start again it gives one turn of the starter motor and then nothing. Dash switches off and resets itself after the keyless button is used to turn the ignition back on.
Suspect its simply a problem with the starter/ kill button but any other ideas ?
Starting Issue
- Been liked: 477 times
Re: Starting Issue
Is this the first time you've turned the bike off with the Emergency off Switch (Kill Switch).
- Stu
- Administrator
- Has liked: 622 times
- Been liked: 598 times
Re: Starting Issue
He has figured out his problem!
It was a loose battery connection!
Maybe check yours before a trip to the dealer
- Has liked: 88 times
- Been liked: 160 times
