part number needed
- Has liked: 1440 times
- Been liked: 409 times
part number needed
I need the part number for a front wheel bearing seal. The bike is a 07 RT
- Been liked: 478 times
Re: part number needed
I find MAX BMW, https://shop.maxbmw.com/fiche/DiagramsM ... d=09082020 more user friendly than RealOEM.
(Usually get the part # from MAX BMW and crosscheck it with RealOEM).
Which seal do you need, left or right, they have different ID.
Left 35mm ID, https://www.motorworks.co.uk/wheel-bear ... 626-2.html
Right 30mm ID, https://www.motorworks.co.uk/wheel-oil- ... 625-1.html
Is this the seal required, if so, looks like it could be the left 35 x 52 x 7 which is shown on the seal. (The right is 30 x 52 x 7).
Thanks for the help Chaps
I need both David. I received a message from the shop and he is sending the correct ones out on Monday. I sent him the part numbers and sizes to make sure i received the correct ones this time.
Thank you both again
