Page 1 of 1
Brake Fluid Change 2011 Twin Cam RT
Posted: Thu Feb 02, 2023 12:58 pm
by Our Gee
Question.
Does a Brake Fluid change (a two yearly service requirement) require "Cycling" of the ABS Pump.
Thanks.
Re: Brake Fluid Change 2011 Twin Cam RT
Posted: Thu Feb 02, 2023 2:59 pm
by sakm
No it's not listed on the service manual to do
Posted: Sat Feb 04, 2023 6:52 am
by Our Gee
Thanks for that sakm. Interesting as I do recall that when I had the Fluid changed on my 2008 Hexhead two different workshops (one main dealer and one independent) both said that the ABS Pump is "Cycled" as part of the procedure. Just wondering what is different between the Hexhead and Twincam systems if, as you say, Pump "Cycling" is not required ? .
Posted: Sat Feb 04, 2023 8:32 am
by sakm
Our Gee wrote: ↑Sat Feb 04, 2023 6:52 am
There is two different types of ABS pump that was used on those models ABS1 and ABS2 great naming eh!
Which meant two different procedures ABS1 required that you bleed the ABS pump and ABS2 you didn't although I can't see that it has to be cycled to bleed it but it is supposed to be checked with a diagnostic tool
Here are the procedures for both types of pump
2003 to 2006
2006 onwards
Posted: Sun Feb 05, 2023 7:13 am
by Our Gee
Once again, thanks for the info sakm.
