Page 1 of 1
Tire Pressure ??
Posted: Fri Feb 03, 2023 7:26 pm
by Randyjaco
I was inspecting my tires today (Michelin Road 6). For the first time ever, I noticed the maximum tire pressure is 42 psi. BMW's recommended cold rear tire pressure for my bike is 42 psi. That is not a problem when my tires are cold. On some of those hot Texas days, on my TPM, I have seen the that pressure rise to over 46 psi. Is this something I should be concerned about? I would prefer not to be stopping every hour to adjust tire pressure. 8^( I am hoping that that maximum is calibrated to reflect Boyle's law. Does anybody have any educated thoughts on this?
Re: Tire Pressure ??
Posted: Fri Feb 03, 2023 7:51 pm
by David.
The maximum load β here itβs 365kg β is the most the tyre can support at a standardised pressure β in this case 42psi.
Posted: Fri Feb 03, 2023 7:53 pm
by sakm
as above
Its cold tyre pressure
Posted: Fri Feb 03, 2023 7:57 pm
by David.
The 42psi is not a maximum pressure, it's the load which is a maximum at that standard cold pressure.
Here's another example, different type of tyre and max. load but the same standard 42psi.
Posted: Fri Feb 03, 2023 11:45 pm
by Randyjaco
Thanks guys. I presumed as much, but just thought I would ask.
