Flapper Valve.
Has liked: 266 times
Been liked: 35 times
Re: Flapper Valve.
sakm wrote: Mon Feb 20, 2023 8:42 am I have a set and they are well worth the money :thumb:
Nice!, how did you find the fit ?.
Did you try polishing them to a mirror finish ?.
How do you find performance, no loss of power ?.
sakm
Has liked: 452 times
Been liked: 396 times
Re: Flapper Valve.
Post by sakm »
Panman40 wrote: Mon Feb 20, 2023 9:00 pm Nice!, how did you find the fit ?.
They fit Pretty well little bit of jiggling to get them bang on though. Top tip dry fit them first and then put a small mark on the joins then take them off and put the gungum on
They are currently off in the process of being sanded and polished up
I couldn't tell a difference in performance to be honest with you or loss in power. I also had/have a straight through exhaust but I have removed that as its just too loud! Wife complains on longer rides and it makes you twist the throttle a lot :lol:
I will be putting them back on when polished up with the stock can then taking the bike for a remap at some point this year anyway
Re: Flapper Valve.
sakm wrote: Mon Feb 20, 2023 9:13 pm They fit Pretty well little bit of jiggling to get them bang on though. Top tip dry fit them first and then put a small mark on the joins then take them off and put the gungum on
Thanks :lol: , I wonder if you could as you say dry fit them, mark all the joints then have those joints welded up so it’s in effect a one piece unit as per the original ?.
I’ve been looking for a cheap end can which actually looks nice just for some fun but there’s very little out there. :?
sakm
Re: Flapper Valve.
Post by sakm »
I don't see why you couldn't have it welded up but you would need to make sure its absolutely spot on!
I got a Beowulf for mine
scunny12
Has liked: 25 times
Been liked: 36 times
Re: Flapper Valve.
Post by scunny12 »
At first glance, I thought why is there an extended carrier to transport cones! :)
Re: Flapper Valve.
sakm wrote: Mon Feb 20, 2023 10:39 pm I don't see why you couldn't have it welded up but you would need to make sure its absolutely spot on!
Looks good!, were you able to use the oem link pipe cover plate with the Beowulf ?.
sakm
Re: Flapper Valve.
Post by sakm »
Panman40 wrote: Tue Feb 21, 2023 6:43 am Looks good!, were you able to use the oem link pipe cover plate with the Beowulf ?.
No it comes with its own
But you can use it on the black widow pipes with stock exhaust
Bike Model and Year: Modified "16" R1200RT
Been liked: 194 times
Re: Flapper Valve.
Panman40 wrote: Mon Feb 20, 2023 9:49 pm
Have the full Arrow system on mine with a PowerCommander.It shifts :mrgreen:
Forgot to say,it was tuned with the baffles out,baffles are a girls thing 8-)
Talisker
Bike Model and Year: R1250RT LE 2020
Re: Flapper Valve.
Post by Talisker »
Thanks to all the contributions to this thread. Butterfly valve seized open at some point over the winter (probably due to not getting cycled).
Bike still under warranty but I didn't want a new downpipe/cat/butterfly assembly just to have the same issue occur again later. The dealer couldn't even tell me if the scrap parts would be re-cycled correctly!
So I've wired the butterfly open (didn't want to faf about removing it). I've removed the servo and cables and fitted the healer. It's a bit louder at low revs but I can live with that.
Thanks again for all the good info in this thread which has enabled my easy fix. :cheers:
Re: Flapper Valve.
I’m still looking for a cheap can, I. Ishtar buy a stainless delkevics right oval and have a local guy who builds custom bikes knock up a link pipe…
Bike Model and Year: R1250RT LE 2018
Has liked: 28 times
Been liked: 87 times
Re: Flapper Valve.
7vwh
Has liked: 12 times
Been liked: 33 times
Re: Flapper Valve.
Post by 7vwh »
Glenn wrote: Mon Oct 09, 2023 7:41 pm
Thank you Glenn for the video. I’ve had problems with a seized valve and had freed it off previously (July 2020) but it soon seized again a month later so I removed the cables and fitted an eliminator. Having viewed the video I had another go, especially at shining up the shaft! and had it fully freed off in ten minutes. The maintenance part starts at 23:47. I bought these (TONITTO 6Pcs Small Wire Brush Double-Ended Brass Brush Stainless Steel Wire Brush for Cleaning Welding Slag and Rust https://amzn.eu/d/a845SQS )
off Amazon to get at the shaft and they worked a treat with a little penetrating fluid 👍
Just waiting for some spray copper grease to come to finish off (Fermit Anti-seize aluminium paste spray, 400 ml can https://amzn.eu/d/3QHKiiu. )
gsamick1250
Bike Model and Year: GSA1250 2019
Re: Flapper Valve.
Post by gsamick1250 »
have freed up valve but get no return from spring! any ideas chaps
sakm
Re: Flapper Valve.
Post by sakm »
gsamick1250 wrote: Sun Oct 29, 2023 5:21 pm have freed up valve but get no return from spring! any ideas chaps
Sounds like it's still stuck to me!
Has liked: 28 times
Re: Flapper Valve.
Where did you lubricate the shaft, at the base of the spring or a little higher as per the video (around 40 minutes)?
