Page 1 of 2
Panniers Repair Project..
Posted: Sun Dec 03, 2023 8:12 am
by EasyRider
There is not a "Project" section on here. So i thought i would put this thread in the "Tips & Tricks" section.
So when i bought my new to me R1250RT last week, i knew the panniers were scratched. Luckly only the black plastic part and not the bike colour painted part. The painted part has the protection film on which i will replace as it is marked.
I will add photos and comments of what and how i have been doing it and what i've used.
So here is a photo of each pannier showing the scratches that need repairing.
As you can see, the right pannier has the worst scratches on it.
- Right Side.jpg (190.73 KiB) Viewed 17909 times
- Left Side.jpg (169.19 KiB) Viewed 17909 times
Re: Panniers Repair Project..
Posted: Sun Dec 03, 2023 10:03 am
by EasyRider
So to repair the scratches to get ready for paint, i will be using these items.
800 grit wet/dry
Fine scotch pad (grey)
Big Boy Plastic filler
Kitchen roll
Panel wipe and lint free cloth
- 1.jpg (325.91 KiB) Viewed 17891 times
- 2.jpg (425.4 KiB) Viewed 17891 times
- 3.jpg (223.32 KiB) Viewed 17891 times
- 4.jpg (175.01 KiB) Viewed 17891 times
Posted: Sun Dec 03, 2023 10:52 am
by EasyRider
So it does not take me long once i get going.
Both the left and right pannier covers are now ready to mask up and paint.
The left pannier did not need any plastic filler.
The high build primer will sort any small marks out.
The right pannier did need some plastic filler.
I always put more on than i need. This way its hard to miss any deep marks.
I also used a blade on the right pannier to remover any high plastic from the scratches.
Will add photos of what i will use to paint them in the next post.
- 5.jpg (196.8 KiB) Viewed 17885 times
- 6.jpg (176.11 KiB) Viewed 17885 times
- 7.jpg (155.79 KiB) Viewed 17885 times
- 8.jpg (200.44 KiB) Viewed 17885 times
- 9.jpg (173.21 KiB) Viewed 17885 times
- 10.jpg (151.86 KiB) Viewed 17885 times
Posted: Sun Dec 03, 2023 11:24 am
by EasyRider
So to paint the plastic part of the panniers you must use a plastic primer.
I use a 1K clear primer whenever i paint unpainter ABS plastic.
I will then use a high build primer (Black) which will hide any little mark left in the plastic.
For the top colour coat, I use a 2K Satin Black.
I like satin paint on black plastics as it look better than matt, and its not as shiny as gloss.
I could colour code them to match the bike.
- 11.jpg (288.69 KiB) Viewed 17881 times
- 12.jpg (225.63 KiB) Viewed 17881 times
- 13.jpg (202.69 KiB) Viewed 17881 times
- 14.jpg (151.48 KiB) Viewed 17881 times
Posted: Sun Dec 03, 2023 11:39 am
by EasyRider
Been thinking for all of 5 mins.
Does anyone know the colour or colour code for the satin silver on the 2019 RT
- 4.jpg (311.35 KiB) Viewed 17877 times
Posted: Sun Dec 03, 2023 12:31 pm
by EasyRider
I think i've found it. Could someone double check for me please.
Glacier Silver Metallic / A83 or WA83
Posted: Sun Dec 03, 2023 1:49 pm
by EasyRider
I've just bought a 30ml touch up. if its the right colour i can the buy 1/2ltr of basecoat.
Posted: Sun Dec 03, 2023 5:14 pm
by Stu
Jesus! You don't mess about
Posted: Mon Dec 04, 2023 12:30 pm
by EasyRider
Posted: Mon Dec 04, 2023 12:33 pm
by EasyRider
Also i'm still on the fence about painting them Black or Silver.
Posted: Mon Dec 04, 2023 4:18 pm
by Capt Sisko
Be careful with those chrome trims as they're only held on by the automotive equivalent of double sided self adhesive tape. I lost one the once, cost over £50 for just one!
Posted: Tue Dec 05, 2023 11:35 am
by EasyRider
Both panniers are now primed in black 2K primer and sanded flat with 800 grit wet/dry.
I then used the grey scotch pad to get in to all the corners.
Getting the inner corners is a must, as that is where the paint could start to lift away.
I am now waiting for the touch up paint to come to see if its the right colour.
If it is i will reprime both panniers with a light grey 2K primer.
If not i will just paint them black, but will put a gloss clearcoat on.
The 2K gloss clearcoat will help with any stone chips. as it's easy to touch up the clearcoat.
Here is a photo of each pannier front. The first photo is of the one that had the most damage.
- 18.jpg (165.15 KiB) Viewed 17721 times
- 19.jpg (138.3 KiB) Viewed 17721 times
Posted: Tue Dec 05, 2023 11:43 am
by EasyRider
A Before & After photo.
- Before and After.png (629.89 KiB) Viewed 17719 times
Posted: Fri Dec 08, 2023 7:54 am
by EasyRider
The panniers are now finished.
I have painted them in 2k Satin Black.
Both panniers have had 4 coats.
The panniers are now back together.
I am very happy with how they have turned out.
The paint and everything i used was free as i had it left over from other jobs.
The 2 times i was down the workshop painting, has cost me £4.40 in electric.
I will add another photo when the panniers are fitted back on the bike.
- 20.jpg (171.23 KiB) Viewed 17671 times
- 21.jpg (164.09 KiB) Viewed 17671 times
Posted: Fri Dec 08, 2023 8:13 am
by EasyRider
Panniers are back on the bike. There out of the wife way now
- 22.jpg (322.84 KiB) Viewed 17669 times
