Clutch and brake fluid change ?
Has liked: 617 times
Apologies if I’ve asked this before but… does the clutch fluid on a 1250rt need to be changed as I don’t see it in the maintenance schedule ?.
Also has anyone changed the brake fluid and purged the abs pump with no issues using the GS911 ?.
:cheers:
Re: Clutch and brake fluid change ?
Anyone :shock: :lol:
Has liked: 99 times
Been liked: 222 times
I thought they used mineral oil in the clutch like on the older versions? If so? That lasts the life of the bike. Does it not say on the reservoir lid?.
Looking over my service history. There is nothing regarding that BMW had changed the clutch fluid.If you wish to change it only use mineral oil. Any make will do
It will have mineral oil in it and its supposed to last the lifetime of the bike
I'm not a fan of this and replaced mine and it was a pig of a job
Thanks for the reply’s 🙏. I was just about to say I’ll get some mineral oil and change it but after reading Sakm*s post I think I’ve changed my mind!.
Our Gee
Been liked: 33 times
Post by Our Gee »
It's just as easy to use the correct "mineral" oil which is Hyspin V10. The BMW Part Number being 21 52 2 455 540. I changed mine a couple of years ago and as SAKM says it can be a bit tricky and requires "back filling" from the Slave Cylinder using a suitable syringe and tubing. At the same time I changed the seals in the Master Cylinder.
09' R1200RT Clutch bleeding DIY, viewtopic.php?p=65595&hilit=v10#p65595
