Page 1 of 1
Crud Catcher by Cymarc Engineering
Posted: Sun Jul 27, 2014 4:17 am
by beemerbaz
I have one of these on my RT to help protect the front engine casing. Mine was powder coated black to match the bike.
http://www.cymarcbikeparts.co.uk/bmw-r1200rt-front-crud-catcher-53-p.asp
Re: Crud Catcher by Cymarc Engineering
Posted: Thu Jul 31, 2014 3:46 pm
by guest2360
One thing to ponder about this if fitted to a 2014 model. Behind the front cover on a pre 2014 RT there is not much more than the bottom pully for the alternator. On the 2014 its a wet clutch. Just thinking that it probably relies a little on the air flow over the cover which it wont get with the catcher fitted. For that reason alone I will be looking at a fender extender.
Posted: Sun Aug 03, 2014 12:21 pm
by Maz12
I was thinking the same  and will also go for the Fender Extender
Posted: Fri Nov 14, 2014 2:57 pm
by Pope
Belt and Braces.......
Cymark and Exdender working in perfect harmony..
Posted: Sat Nov 15, 2014 5:29 pm
by beemerbaz
Had mine on a year now with the Fender Extender also with no issues except a rather cleaner engine [emoji106]
Posted: Wed Apr 22, 2015 9:17 pm
by Steveeung
I have just fitted the same set up to my 1200 LE and haven't ridden it yet (fitted tonight) but it does look as if the extender will hit the crud catcher when the shocks bounce. Will let you know ... :eek:
I notice Pope's pic has the motif RT on it. Mine has nothing but it is made by Cymark.
Posted: Wed Apr 22, 2015 10:14 pm
by Pope
Steveeung wrote: I have just fitted the same set up to my 1200 LE and haven't ridden it yet (fitted tonight) but it does look as if the extender will hit the crud catcher when the shocks bounce. Will let you know ... :eek:
No problems with clearances here. And remember, there is very little front dive, due to the Tele-Lever system.
BTW, i asked for the RT logo to be added on mine (no cost option).
Posted: Thu Apr 23, 2015 9:51 am
by Steveeung
You are so right - works a treat - thanks!    C:-)
