Page 1 of 1
How do you check your oil???
Posted: Wed Jul 30, 2014 8:13 pm
by chrismckay
What rules do you apply to your oil level checking ritual??
Centre stand? warm engine? Side Stand? hand stand?????
There are so many variables on google and as I am new to this boxer engine, I would like to hear your views.. :D
Re: How do you check your oil???
Posted: Wed Jul 30, 2014 8:37 pm
by guest2360
Always use the centre stand but make sure the ground is level. If its leaning left or right by just a bit you will get an incorrect reading. Think the book tells you to check it when hot but switched off for a few seconds. Window is normally empty when the engine is running.
Posted: Wed Jul 30, 2014 9:05 pm
by beemerbaz
Sometimes handy carrying a small LED torch or similar.
Posted: Thu Jul 31, 2014 8:09 pm
by stever1
RTM, its all in there.
Posted: Mon Aug 04, 2014 10:42 pm
by chrismckay
stever1 wrote: RTM, its all in there.
too easy  ;)
Posted: Sat Nov 08, 2014 2:39 pm
by David.
From the Rider's Manual
The oil level varies with
the temperature of the
oil. The higher the temperature,
the higher the level of oil in the
sump. Checking the oil level with
the engine cold or after no more
than a short ride will lead to misinterpretation
of oil level.
In order to ensure that the engine
oil level is read correctly,
check the oil level only after at
engine operating temperature.
Switch off the engine when it is
at operating temperature.
Make sure the ground is level
and firm and place the motorcycle
on its centre stand.
Wait five minutes for the oil to
drain into the oil pan.
Knowing that the oil level will rise when the engine gets hot, I like to check it at home from cold before a ride, seeing the oil near the top of the sight glass.
(The difference between MIN and MAX is 0.5 litre.)
As mentioned, a small torch can be helpful when checking the oil level.
