Split bearing puller
- Been liked: 5 times
I am trying to find a split bearing puller like the one in the pic. I need one that will cope with a 150mm bearing/gear but don’t want to buy one as I am only going to use it twice. Has anyone got one I can borrow/rent somewhere close to East Anglia?
Re: Split bearing puller
Is it similar to the one I posted? I need to get in a small gap behind the gear to pull it off the spindle. Normal claw types won’t work - I’ve tried!
- Dartman340ta
You can rent one at most auto parts stores advanced O Riley’s I suppose there are others that do it also
Google is normally your friend for such things but alas not for renting one of these.
