Page 1 of 2
Intermittent TPMS
Posted: Sun May 26, 2024 11:49 am
by Stu
Just recently I have noticed that the rear TPMS is not registering a pressure
I don't get a low pressure warning just no reading
Is this a sign of a failing sensor or flat batteries?
Re: Intermittent TPMS
Posted: Sun May 26, 2024 11:53 am
by 60Aviator
Battery is on its last legs.
Posted: Sun May 26, 2024 1:18 pm
by Stu
Next question what batteries do the TPMS take?
Posted: Sun May 26, 2024 4:47 pm
by David.
Don't think the batteries are designed to be replaced,
viewtopic.php?p=38354&hilit=tpms+battery#p38354
Schrader make a replacement,
viewtopic.php?p=59978#p59978
Posted: Sun May 26, 2024 5:13 pm
by Stu
There not but doesn't mean you can't
From having a Google it seems the battery is a cr2050 although others have use different ones with good results
Posted: Sun May 26, 2024 6:09 pm
by simbo
sakm wrote: Sun May 26, 2024 5:13 pm
Easy job! Did mine with a craft knife and hot glue gun a couple of years ago.
Posted: Sun May 26, 2024 7:47 pm
by k9doc
Don't know if it's different on the later bikes, but on my 2013 if it was the battery you get the dreaded yellow triangle plus 'RDC' message briefly on start up. If it's just -- or --/-- with the yellow triangle, then chances are it's dodgy sensor(s).
AliExpress worth a look. £10 for a pair of new ones. I was tempted for my 2013 RT if warranty hadn't covered and replaced with a 'BMW' one @ £104 + VAT. Same part #. Just had a footpeg lowering kit from them and looks just as good as the Wunderlich ones and less than a quarter of the price. Pays your money..........!
Posted: Sun May 26, 2024 8:18 pm
by Stu
@k9doc I get no warnings on the dash just the two lines where the pressure should be as if the sensor has not started to work like when you first turn it on before you ride
Posted: Sun May 26, 2024 8:42 pm
by k9doc
sakm wrote: Sun May 26, 2024 8:18 pm
Beats me - no warning light.
Posted: Sat Jun 01, 2024 12:31 pm
by 60Aviator
If you do a search on the other forums there is a KTM part number that is the same thing as BMW but was only $65 when I got one vs $200+ for BMW.
Posted: Sat Jun 01, 2024 11:17 pm
by Stu
60Aviator wrote: Sat Jun 01, 2024 12:31 pm
Yes found all that
Also found a place here in the UK supplying them for £60 each
Today it totally scrapped itself and showed an error then started to work again!
Posted: Fri Jun 14, 2024 9:10 pm
by Stu
took the decision to buy two new TPMS
Still waiting for one to be delivered but the faulty one has been replaced and is working fine now
I went for the Schrader 3142M which is the ones for the KTM the BMW one is the 3141M but they are all the same
You also have to replace the bolts too
Posted: Sat Jun 22, 2024 6:57 am
by Panman40
sakm wrote: Fri Jun 14, 2024 9:10 pm
TPMS
That’s useful to know Stu, so you didn’t bother messing with batteries then ?, where may I ask did you purchase the
tpms from ?. I suspect my 2019’s will need replacing next year.
Also did you go to a tyre dealer to have th tyres removed , go home to fit the sensors then go back for refitting ?.
Posted: Sat Jun 22, 2024 9:10 am
by Stu
Panman40 wrote: Sat Jun 22, 2024 6:57 am
No I couldn't be arsed to faff about with batteries! I think I'm getting too old for that crap these days
I found them on ebay I ordered two but only have one at the min as the other one is on back order!
No I removed the tyre and fitted it sensor then refitted the tyre then balanced the wheel
Posted: Sat Jun 22, 2024 4:36 pm
by Panman40
sakm wrote: Sat Jun 22, 2024 9:10 am
I know what you mean
, oh are you on Michelins ?, they look very tight to get on and off
