Paint code for the SanMarino blue paint
STeinar
Post by STeinar »
Dos anyone have the paint code for the SanMarino blue paint ?
Going to spray the top box and the two grey Headlight housing parts.
[attachimg=1]
STeinar
Re: Paint code for the SanMarino blue paint
Post by STeinar »
BTW: have found this:  Quartz blue metallic  BMW  B51, but not sure if t here are others?
Hi STeinar, have you tried using this BMW VIN Decoder, http://bimmer.work/.
Looks like B51 could be correct.
Real OEM shows the mix code as B51
Spot on & here's the link to RealOEM, http://www.realoem.com/bmw/enUS/showpar ... Id=51_9787.
richardbd
Post by richardbd »
Why not do it the other way around - paint the blue bits grey?
You'd be amazed how much faster the bike is...
:alas: :alas: :alas:
STeinar
Post by STeinar »
Thank you everyone  ^-^
Will bring this to the painter - and hope he has the needed tables to find the right one
STeinar
richardbd wrote: Why not do it the other way around - paint the blue bits grey?
genius
STeinar wrote:Will bring this to the painter - and hope he has the needed tables to find the right one
San Marino Blue is used on some BMW Cars, Code B51 cross-references to Ditzler PPG 934530,
http://camaroattitude.com/cgi-bin/color ... ame=Silver
