Hello...2005 1200RT lugging and missing under load above 5000 rpm
MOONEY
Post by MOONEY »
Hello out there. I'm new to the site, but not a new Beemer owner.
Came down with a sudden and intermittent problem with my baby, an 05 R1200RT with only 30,000 miles: It's lugging and missing when I roll the throttle on under load between 5 and 5500rpm. It seems to miss and lack power when accelerating past 80mph, in 5th or 6th. At lower RPM's it seems to run fine. Don't know where to start, fuel related or electronic. Had the standard service at 26,000 with new plugs, filter etc... My battery is 7 years old, and I just ordered a new one from Beemer Boneyard. Thought I'd start there and see if the problem disappears.
Any suggestions?
Hate to take it to the BMW shop before I exhaust all other options....$$$$....
T6pilot
Re: Hello...2005 1200RT lugging and missing under load above 5000 rpm
Post by T6pilot »
My buddy had same issue with his 2006
It was a upper coil failure. He checked by pull coil and starting bike, using insulated gloves see if you can get a spark between coil and plug, if so go to opposite side. For some reason upper coils fail more often
MOONEY
Post by MOONEY »
Thanks T6.
I'll check the coils.
Appreciate the response!
This thread from BMWSportTouring, http://bmwsporttouring.com/ubbthreads/u ... ber=640038
sounds like exactly the same problem on a 2007 RT, might be worth a read.
Looks like the problem was a cracked sparkplug, checking the Primary Coils does seems like a good place to start.
"The dealer computer shows nothing, they say it's perfect", & this was before the sparkplugs were changed by the Dealer.
MOONEY
Post by MOONEY »
Thanks DaygoDavid!
That was very helpful.
I ordered a new battery, next thing is to check the plugs for cracks.
I'll post a note when I get it fixed.
cmath99
Bike Model and Year: 2019 R1250RT
Canada
Post by cmath99 »
i'm having the same issue...did you get yours fixed? what was the issue? a cracked sparkplug?
