Morning all,
Just removed my rear wheel to have the Roadsmart renewed and I have noticed that where the wiring enters the bottom of the rear suspension unit (ESA model) the rubber boot is "split". Further investigation by removing the lower section the the mudguard shows that when the suspension is fully extended, such as when the bike is on the centre stand, the wire has next to no free play. This means that at every cycle of the stand a strain is put on the wire. I have looked further up and behind the rear fairing and there does not seem to be any scope to provide more "slack". I have looked at the MAX BMW parts fiche and it looks like the wire is not listed as a separate part and comes with the Suspension Unit !. Question, does anyone know if this wire can be "un-plugged" from the Suspension Unit as this this would make a repair such as applying "Shrink Wrap" easier.
Many Thanks.
Rear Suspension Wiring Problem. 2012 Twincam
- Been liked: 476 times
Re: Rear Suspension Wiring Problem. 2012 Twincam
Having just checked my 2012 TC, there seems to be plenty of "slack" in the wire at the shock absorber when the bike is on it's centre stand.Our Gee wrote:Further investigation by removing the lower section the the mudguard shows that when the suspension is fully extended, such as when the bike is on the centre stand, the wire has next to no free play.
Could the wire be disconnected at the other end, repaired & rerouted, the main wiring harness may have some movement.
- Been liked: 33 times
Managed to obtain another couple of inches of "slack" although it did mean dismantling the rear end, Rack, Offside rear panel etc. The wire from the Shock goes to a plug and socket which is mounted on a removable plastic bracket. The bracket had a "spare" mounting lug which was a couple of inches nearer to the shock so that's where it now lives. The split rubber boot at the shock end is now wrapped up with tape until I can think of a more permanent solution as it's not possible to get "shrink wrap" over the plug.
Could the split rubber boot be super glued.Our Gee wrote:I have noticed that where the wiring enters the bottom of the rear suspension unit (ESA model) the rubber boot is "split".
(Have successfully glued some rubber tap washers into the open ends of the heated grips on the XJ650).
