So, RT goes in for 12k service. I've had it just under two years but it's a suspension recall reject, so is actually 2.5 years old and out of warranty - though I took the extended one as soon as the OEM one elapsed.
Get a call from dealer; the exhaust valve is seized.
OK, so fix it.
It's out of warranty.
I have an extended warranty.
Exhaust not covered.
OK - so how much?
Well, trouble is valve is embedded in down-pipes, so pipes have to be replaced. Part is £1,300!! However, some good news - BMW have offered to pay for part as goodwill gesture, if you'll pay £72 for the labour to fit it.
How mad is that - on so many levels???
BMW Warranty Madness...
Re: BMW Warranty Madness...
Think they did the same for Casbar last month. He only had to pay £60
RTman10 wrote: Think they did the same for Casbar last month. He only had to pay £60
plus VAT = £72
Right. Think he just said £60.
Yep only £60, but will check the bill. Good news is you get another 2 year warranty on the exhaust 8)
Just checked my bill it was £60 plus VAT. Whilst I was there, they also found my rear brake calliper was seized to freed that off as well. Funny how that wasn't spotted two weeks before on my famous 6k service that I didn't need and didn't have the oil and filter change
My log book now shows next service is 12k, which is wrong, as I had the oil changed at the annual service in January at 3k, then the 6k didn't do the oil, so the oil needs doing at 9k, not 12k. Hey ho! On 7k now, so by January and the annual it should be around 9k, so all will be good. But then in 3k time, it will need the 12k service.
I would copy that lot to BMW Customer Services because they are feeding you c..p.
We have been here before and it's always 6K to the next one and they are unable to reset your warning light to anything but +6 K. They can cheat on the date though.
Richard will be pleased he's not paid more for his flap.
RTman10 wrote: I would copy that lot to BMW Customer Services because they are feeding you c..p.
Yeh I know, but fed up with all the service crap, so will sort myself
