guest3074
Post
by guest3074 » Wed Nov 02, 2016 12:00 pm
Yes by RTMan
Posts: 833 Joined: Wed Jul 06, 2016 9:46 pm
Has liked: 80 times
Been liked: 87 times
Post
by Sullivj » Wed Nov 02, 2016 12:09 pm
Sorry, I must have missed that one.
Happy to go wherever, whenever, as long as it's not during school holidays.
Posts: 8630 Joined: Fri Nov 07, 2014 7:29 pm
Been liked: 476 times
Post
by David. » Thu Nov 03, 2016 12:01 pm
Been doing a bit of "Google Mapping", if the Cotswolds (Tewkesbury) was the chosen venue, this may cover three bases.
Tewkesbury to Ross on Wye is 25 miles in 30 minutes.
Tewkesbury to the NEC Birmingham is 50 miles in 1 hour.
From Tewkesbury, this would give options to visit either or both of two other suggested venues.
There's both a Premier Inn & a Travelodge next door to each other, plus a Brewers Fayre Pub/Restaurant.
Any thoughts?
David. on Thu Nov 03, 2016 12:18 pm, edited 1 time in total.
GuzziRick
Posts: 60 Joined: Sat Jul 09, 2016 3:30 pm
Post
by GuzziRick » Thu Nov 03, 2016 12:20 pm
Hi David sounds a good idea to me, but I've just done a quick search of hotels in Tewksbury for 8th & 15th July and most are fully booked including the Prrmier Inn, it could be something to do with an international medieval festival that is held on on of the weekends in early July but hasn't had the date set yet so rooms could become available.
Has liked: 80 times
Post
by Sullivj » Thu Nov 03, 2016 12:37 pm
Tewkesbury Travellodge has at least 7 rooms available on the 8th July 2017. I just checked.
Are you sure you spelt ir correctly Rick - it's wrong in your post.
Post
by David. » Thu Nov 03, 2016 2:38 pm
Looking at the Travelodge website for Tewkesbury,
https://www.travelodge.co.uk/ , the max. number of rooms you can search for is 9.
In the month of July 2017, the 8th looks likes the best value for money at £40 (non-refundable) or £57 (flexible), room only.
David. on Thu Nov 03, 2016 3:06 pm, edited 1 time in total.
leonjennings
Posts: 96 Joined: Sat Oct 29, 2016 10:26 am
Been liked: 1 time
Post
by leonjennings » Thu Nov 03, 2016 2:45 pm
7th-9th July is the British GP at Silverstone. I along with hundreds of thousands will be attending that event. May i suggest you do not consider these dates?
2012 SE
Post
by David. » Thu Nov 03, 2016 2:57 pm
At Tewkesbury, the next best value for money is either the 1st or 22nd at £45 (non-refundable) or £63 (flexible), room only.
When the venue is agreed, the date & accommodation can be sorted.
The Tewkesbury Travelodge has an "on-site restaurant and bar serves breakfast and tasty evening meals".
David. on Thu Nov 03, 2016 3:03 pm, edited 1 time in total.
guest3954
Post
by guest3954 » Thu Nov 03, 2016 4:07 pm
If availability is a problem - does it have to be a weekend?? ???
Post
by David. » Thu Nov 03, 2016 5:01 pm
The Travelodge at Tewkesbury has 71 rooms, with full availability for July 2017.
They can be contacted directly on 020 3195 4680, online booking is cheaper.
David. on Thu Nov 03, 2016 5:05 pm, edited 1 time in total.
Post
by guest2360 » Thu Nov 03, 2016 5:07 pm
Am I right in thinking Travelodge require money on booking ie don't do pay on arrival.
Post
by David. » Thu Nov 03, 2016 5:36 pm
Yes, I believe you pay when booking as per their T&C's,
https://www.travelodge.co.uk/terms-conditions#payment , unless advised otherwise.
"All payments are due in full at the time of booking unless you are otherwise advised by us."
Post
by guest2360 » Thu Nov 03, 2016 5:42 pm
Safer with Premier
. Pay on arrival, or cancel up to the day of arrival for free.
Posts: 2670 Joined: Wed Jan 27, 2016 6:25 am
Been liked: 46 times
Post
by Casbar » Thu Nov 03, 2016 6:13 pm
Depending on which rate you have, you can caner both upto the day of arrival if booking a flexible rate. If booking a saver rate, you lose if you cancel, but it is cheaper.
Has liked: 80 times
Post
by Sullivj » Thu Nov 03, 2016 10:21 pm
So, are we heading towards the 15th July in Tewkesbury? Works for me.
I'm happy to commit and pay for my Travelodge now if others are too?
