Is Mahle the same as OEM parts
Re: Is Mahle the same as OEM parts
779 above for the LC
Alfred
Post by Alfred »
Well that means then that my dealer installed the wrong filter.
Another reason NOT to use them anymore.
2014 R1200RT-LC
Not until he swapps it for the correct one.
Been liked: 477 times
Alfred, dare I ask which oil you used.
Alfred
Post by Alfred »
DaygloDavid wrote: Alfred, dare I ask which oil you used.
Very expensive fully synthetic Liqui Moly 4T synth 5W-40 Street Race.
2014 R1200RT-LC
Alfred wrote:Very expensive fully synthetic Liqui Moly 4T synth 5W-40 Street Race.
That's a new one on me, it hasn't got BMW (Shell) stamped on it, but at least it's made in Germany. (Didn't know that Germany had any oil fields.)
Ring another dealer and ask them what oil they use.  Then get really mad with the one that put that in your sump.  Looks like the correct grade though, but no idea what quality
Alfred wrote:The Oil Filter I just took off.
Sounds like Alfred is doing his own oil & filter change, not a BMW dealer.
Alfred
Post by Alfred »
DaygloDavid wrote: Sounds like Alfred is doing his own oil & filter change, not a BMW dealer.
Correct
The dealer put shit oil and wrong filter on it. I am sick of paying for rubbish.
Liqui Moly is top of the line oil, but also comes attached with a matching price tag. Over here in Australia getting 5W-40 oil that is also MA2 is next to impossible to get. Fortunately I located an Internet Whole Seller who imports the oil.
2014 R1200RT-LC
As is says on the tin, the Liqui Moly is synthetic, API SM & JASO MA-2.
The BMW (Shell) Advantec stuff is systhetic, API SN & JASO MA-2.
The BMW spec. is API SL & JASO MA-2, therefore, both the above oils meet & exceed the requirements.
gogs01
Post by gogs01 »
DaygloDavid wrote: As is says on the tin, the Liqui Moly is synthetic, API SM & JASO MA-2.
My Rider's manual says :
"Additives (eg molybdenum-based) are not permissible because they can attack coated components of the engine..."
Does this mean we should worry about using an oil called "Liqui Moly" ?
gogs01 wrote:My Rider's manual says :
No, it's just a brand name, https://pim.liqui-moly.de/pidoc/P000261 ... 0.0-en.pdf
gogs01
Post by gogs01 »
DaygloDavid wrote: No, it's just a brand name, https://pim.liqui-moly.de/pidoc/P000261 ... 0.0-en.pdf
