Front Speed Sensor.
Front Speed Sensor.
Hi all just a bit of advice/help. I've got a 2010 RT. Whilst riding on the motorway in the pouring rain this evening my break failure light suddenly lit up! I pulled off the motorway and tested my breaks as safely as possible and the seemed to be working fine. I stopped and had a quick visual but couldn't see any fault. I continued home and had a proper look and found that the front speed sensor cable had been rubbed/cut by the edge of the disc. Does anyone know how easy it is to replace and will the bike need plugging in to get the fault re set. Thanks in anticipation.
- Been liked: 337 times
Re: Front Speed Sensor.
The following info. has been taken from the Haynes manual.GuzziRick wrote:Does anyone know how easy it is to replace and will the bike need plugging in to get the fault re set.
The ABS sensor is secured by a screw to the fork slider.
The sensor wiring is held in place with clips on the slider & brake hose.
The fuel tank needs to be removed to access the connector on the ECU.
Any fault code arising from the sensor damage will have to be cleared from the control unit memory using a diagnostic tester.
Thanks David I'll give it a go this weekend if I can get the sensor tomorrow.
- Been liked: 24 times
Just had a look on the Max BMW Parts Fiche and strangely the Front Sensor and Cable, although depicted do not appear in the parts list. A quick look at the pre- Twin Cam fiche does however show that this item is priced at over $200. (Ouch). Would a repair to the damaged cable not be possible ?.
Our Gee wrote: Just had a look on the Max BMW Parts Fiche and strangely the Front Sensor and Cable, although depicted do not appear in the parts list. A quick look at the pre- Twin Cam fiche does however show that this item is priced at over $200. (Ouch). Would a repair to the damaged cable not be possible ?.
It shows on Real OEM under the Brakes section on the second diagram. $ price shown as 98.
Rainbow BMW have it listed as No. 11, Wheelspeed sensor, Part Number 34527677824, cost £76.01, https://www.rainbowbmw.com/BMWETK/Produ ... 402515.php
I don't use ebay but found this, https://www.ebay.co.uk/p/BMW-Wheelspeed ... 1925281094
Thanks for the help gents, I'll give a repair a go and see if it can be reset next week if not I'll go for a replacement. Cheers
