R1200RT TC (2011) Rear Brake Rotor Replacement
schmails
Post by schmails »
Hey all.
My 2011 K26 TC has 21.5K Miles on it, and is in the shop getting new tyres, and TPMS replacements (6 years... meh).  Anyway, I get a call that the rear brake rotor is past minimum spec and should be replaced.  I see previous posts indicating that usual rear disc wear is about 50-60K miles.  Is it possible I need a new rear disc?  I don't use the rear brake that much, other than the balancing.  I think the bike is on 2nd set of pads (and they still have some left).
Along with this, I was not going to pay for an OEM rotor (crazy!).  Anyone recommend EBC rotors?  (and what is the model number?)
Thanks!
--ChrisD
Re: R1200RT TC (2011) Rear Brake Rotor Replacement
schmails wrote:I get a call that the rear brake rotor is past minimum spec and should be replaced.
What is the measured thickness of the rear rotor/disc.
schmails wrote:I was not going to pay for an OEM rotor. Anyone recommend EBC rotors, (and what is the model number.)
In the UK, the OEM rear disc is £197.86, EBC list part no. MD671 at a cost of £107.51.
schmails
Post by schmails »
Thanks. I would typically do this replacement myself... but it happened to be in for inspection anyway.
I asked them to button it up... and I'll do brake rotors and pads myself, and take it back or elsewhere to finish my June inspection.
I would like to measure the rotor myself and see how close to 4.5mm I am.
