Leaking oil
ddevane
Leaking oil
Post by ddevane »
Hi there
Hoping to lean on people's expertise here.
I have an R1200RT 2005
Running well but started a leak a couple of months ago. First a spot or two but seems worse. Not so bad that oil has needed to be topped up but enough to cause me concern and oil leak on floor.
When I look at it, it seems to me to be coming from the casing around the sump. Will check and torc bolts that i can see around sump (unless anyone advises differently).
Would really welcome any thoughts or help?
Thanks.
Declan
Newman7096
Re: Leaking oil
Post by Newman7096 »
Maybe the oil pressure switch seal or crank position sensor seal. Can you see anything when it's running?
Badabing
Re: Leaking oil
Post by Badabing »
Use gunk or any similar degreaser and get the area well cleaned. That will give you a better chance of seeing the leak itself or at least see some witness marks to give you a clue as to the problem
ddevane
Re: Leaking oil
Post by ddevane »
Thank you Newman7096....will check that.....you wouldn't have a pic of where they located? Waiting on dealer to get manual in (2 weeks now).
@Badabing......yeah, will do; will strip down lower trim and clean her up well to see if can see source
Noticed that couple screws on casing not as tight as should be so tightened those easy accessible....no difference and perhaps even slightly worse!
Re: Leaking oil
Having looked at the photos again, could the oil be emanating form the oil filter sealing ring, although the filter itself looks dry.
