Muffler noise (more) withoput changing to Remus etc
Has liked: 99 times
Been liked: 225 times
Re: Muffler noise (more) withoput changing to Remus etc
Have you checked your spark plugs since fitting it? Just to see if its running lean or not? Has it affacted the low down torque due to the lack of back pressure? Looks good 👍
simbo wrote:Have you checked your spark plugs since fitting it? Just to see if its running lean or not?
Following the change of muffler, would the Oxygen sensors take care of the mixture?
Has liked: 99 times
David. wrote: Following the change of muffler, would the Oxygen sensors take care of the mixture?
The ECU can make 'minor' adjustments to the fuelling from the information it receives from the various sensors. Removing the silencer isn't usually classed as a minor adjustment  ;)
Gman1969
Post by Gman1969 »
any chance of a video, would love to hear it
Zapata
Post by Zapata »
David. wrote: That looks cool, what is it & where did it come from, thanks.
Is just a exhaust tip that I got from the Autoparts store.
- 2012 R1200RT (0440),  2011 HD Softail Fatboy and  2006 HD V-ROD VRSCR Streetrod.
Zapata wrote:Is just a exhaust tip that I got from the Autoparts store.
Looks a perfect fit, including re-using the original clamp, what is the ID of the exhaust tip.
guest4915
Post by guest4915 »
The oxygen sensor is there to keep the mixture lean for emissions purposes and already keeps it leaner than optimal for power and performance. In addition, they usually only operate in the lower half of the rev range and under certain throttle conditions.
Zapata
Post by Zapata »
simbo wrote: Have you checked your spark plugs since fitting it? Just to see if its running lean or not? Has it affacted the low down torque due to the lack of back pressure? Looks good 👍
I just installed last night and have not had a chance to test it.
Zapata
Post by Zapata »
David. wrote: Looks a perfect fit, including re-using the original clamp, what is the ID of the exhaust tip.
the header ID is 6.35cm, the exhaust tip is like 6.50cm. it was a very tight fit.
Maz12
Post by Maz12 »
Any chance of a video, I too would love to hear it
Zapata
Post by Zapata »
Negative. The flapper was not removed. I think the flapper valve will take care of the leaning or back pressure. Please correct me if I am wrong.
