Instrument cluster adjustment?
jrk36
Post by jrk36 »
[size=14px]The instrument panel on my 2015 R1200RT appears so stiff that the plastic deforms before I get actual movement - I'm scared to press harder in case I hear the case crack [/size][size=14px]
Re: Instrument cluster adjustment?
Stop.  It doesn’t adjust
smileymiley
Has liked: 6 times
Been liked: 11 times
Post by smileymiley »
RTman10 wrote: Stop.  It doesn’t adjust
Yes it does!
Cornishboy16
Post by Cornishboy16 »
Yep, mine adjusts it is a bit stiff but it does move  :kacsint2:
Been liked: 46 times
Mine moves, but it doesn't stay in any position other than the starting one :)
Has liked: 99 times
Been liked: 227 times
Hammer?  ;)
Sprintgull
Post by Sprintgull »
Mine does shift eventually, but it's hardly graceful.  As the manual says - press in the middle.  To be honest once it did move I wondered why I bothered and haven't moved it since.
aweight
Post by aweight »
Be brave, spread the load using both hands, one at the top middle, one at the bottom, press on the edges, not the clear screen, it will move!
R1200RT LE San Marino Blue
Casbar wrote: Mine moves, but it doesn't stay in any position other than the starting one :)
That’s why I thought/knew there was no adjustment.[/quot
k9doc
Has liked: 7 times
Been liked: 16 times
Post by k9doc »
So that means that springtull, cornishboy, smileymiley and aweight all must have dodgy instrument panels, oh and the bloke who wrote the manual is also wrong. This could lead to compensation claims if BMW says it can move and gullible owners believe the manual, then bust their instrument panels trying.
Chris
k9doc wrote: ^^^^^
Probably 😱😱
guest2383
Post by guest2383 »
Sorry guys - only just seen this thread but will throw my two-penneth worth in:
The instrument cluster / binnacle does adjust and mine also stays in place.
the method to adjust it is to put upwards pressure on the "handle" section below the cluster (squeeze this upwards as you tilt the cluster up and down) - not the best design in the world and it does feel quite fragile, but once in the correct position, release the plastic section below it which locks it in position.
Hope this helps. :-\
