Diagnostic port
Beagle
Diagnostic port
Post by Beagle »
Anyone know what diagnostic port my bike has 10 pin round or 16 oblong and where it is?
Reaper999
Re: Diagnostic port
Post by Reaper999 »
If your bike is a 2018 then it will have the OBD Port. Looks the same as fitted to all cars since around 1996.
Beagle
Re: Diagnostic port
Post by Beagle »
Reaper999 wrote: If your bike is a 2018 then it will have the OBD Port. Looks the same as fitted to all cars since around 1996.
Thanks any idea where its located. Thinking of the GS-911.
guest5886
Re: Diagnostic port
Post by guest5886 »
It's in the battery "compartment", impossible to miss. You need to remove the lower right hand side panel to get there, a one minute job (quite literally).
Beagle
Re: Diagnostic port
Post by Beagle »
ElPolloDiablo wrote: It's in the battery "compartment", impossible to miss. You need to remove the lower right hand side panel to get there, a one minute job (quite literally).
Thanks again for your help.
Beagle
Re: Diagnostic port
Post by Beagle »
Is this it below the red jump start terminal? If it is, is the diagnotic the plug or the socket it goes in. In my VW Tiguan the diagnostic is an oblong socket you plug into.
Been liked: 477 times
Re: Diagnostic port
How to locate the Diagnostic connector on your BMW motorcycle, https://www.hexcode.co.za/products/gs-9 ... motorcycle
R1200RT LC underneath the triangular panel on the right.
In later (2016+) EURO4 compliant bikes, the connector will be the rectangular 16 pin.
