Top Case Connector
circlehappenork
Top Case Connector
Post by circlehappenork »
Hi, I've got two questions about the cylindrical connector for the big RT/LT('14-'18) top case:
1. How do I open up the male part of the 10 pin connector? http://www.autotestaid.com/productshow.asp?id=1195
2. Which wire form the top case is going to which pin number?
Last edited by circlehappenork on Wed Apr 03, 2019 10:13 am, edited 1 time in total.
Re: Top Case Connector
Is this thread on BMWLT any help, https://www.bmwlt.com/forums/rt-series/ ... -case.html
Here is a picture of the connector coming from the top box.
https://goo.gl/photos/n6Gc1dffv1Y5B6Z46
https://goo.gl/photos/wV11rRjJpN6jjMo99
circlehappenork
Thanks David.
The second picture answered my second question. I've read through the topic on the lt forum, but didn't found how to disassemble the connector to be able plug in the wires from top case.
Atm my connector looks like this.
circlehappenork wrote:I've read through the topic on the lt forum, but didn't found how to disassemble the connector to be able plug in the wires from top case.
Does the connector actually disassemble, or is a method similar to that in this video required, https://www.youtube.com/watch?v=-7oSpcL1jBY
circlehappenork
Yep, you're right David. I've got to push it out. Thanks so much!
This is the tool which the guy in the video used, https://www.lislecorp.com/specialty-too ... minal-tool others are available, might be worth contacting Lisle.
Lisle - Wire Terminal Tool Kit, https://www.youtube.com/watch?v=K6FLYaPcUrk
