RT LC rear brake pedal lowering
adventureboy
Post by adventureboy »
I saw somewhare on here that a guy was looking to lower his rear brake pedal as it was too high, well mine was the same and the adjustment didnt seem to work, so I went on the look out for a solution
Found it Wunderlich make a rear brake lowering kit for a 1200R and 1200RS which fits the 1200RT although they say it does not !! without a problem ive got one fitted now and the lever is exactly where I want it its lowered by about 19mm which is fine
anyone need a piccie or the part number just give me a shout the plate whth delivery was £9 could have made it for pennies if i had the dimensions
Rob
kioolt
Re: RT LC rear brake pedal lowering
Post by kioolt »
The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
Been liked: 25 times
Post by beemerboy9 »
kioolt wrote: Ilium makes ones for the wethead RT.
https://www.iliumworks.com/BMW_Motorcycle_Accessories.cfm?pn=30%2D600&pID=121
Not quite the same thing. Take a look at this - the whole footrest assembly is canted forwards and downwards.  Inexpensive if it does the job.
adventureboy
Beemerboy
thats the one I fitted and it works fine and at only £9 delivered its a lot cheaper than the other above option
Rob
ExGMan
Post by ExGMan »
I bought that pricey Illium piece for my 2015 RT two years ago. Works fine, but I wish I had looked for the Wunderlich piece!
realshelby
Post by realshelby »
Or....you can simply unhook the brake lever from the pushrod bracket. Unscrew the bracket from the pushrod ( that goes into the rear master cylinder ). Remove the lock nut that normally locks against the bracket ( not enough room to leave it installed ). Cut off the pushrod a bit, put some loctite on the threads and screw the U shaped bracket back on. Install pin through brake lever and pushrod.
Done. Works good and costs next to nothing.
