Hi All
I am looking at buying a 2107 R1200RT, I took one for a test drive today (first time for this bike) and found the engine to be a "little rattly' and low speed or idling,
(something like a quiet diesel engine). Is this normal or bad news?
It has 27000 ks on the clock
Everything else lived up to what I have been reading on this site so I am hoping for good news.
Thanks in anticipation.
A
a bit noisy
- Been liked: 33 times
Re: a bit noisy
I would say that being new to the type your best plan would be to test ride a number of bikes then you can compare . If the bike you rode indeed has a problem this will become apparent. Or better still, take someone along with you who knows about BMW Boxers.
- Been liked: 476 times
Re: a bit noisy
This thread from BMWLT might make an interesting read on the subject, https://www.bmwlt.com/threads/2016-rt-w ... ne.162417/
Re: a bit noisy
Hi
Thanks for the advice given, I have also spoken to a local mechanic and it seems all is ok.
So I have gone ahead and purchased the bike and get to pick it up in a few days.
Heres to some great times on the road
Re: a bit noisy
Is like a "pinking" sound? I bought my '15 with 7k on the clock, took it back to the dealer who replaced the cylinder heads under warranty. When it came back it sounded no different, dealer swore blind that all was well. I'm up over 25k now, no problems at all, I've just got used to the noise. HTH
- Has liked: 1 time
- Been liked: 11 times
Re: a bit noisy
I had a 2005, and now a 2009. Th 09 will make a thin tinking noise if I have to accelerating hard in the 3-4,000 RPM range as in an evasive maneuver with no time to downshift. Not loud, sort of like if you took an aluminum rib from an umbrella and tapped it on a hard surface. It disappears almost immediately as the revs mount. I never heard this on the 2005, and the 09 runs fine, good gas mileage, etc. This doesn't sound like your noise (which I agree with other posters is just a characteristic of the boxer engine) but I was wondering if anyone else has heard the tinking?
Re: a bit noisy
While I cannot "hear" the bike from here.....
I would say the Wethead is far from a quiet engine. Certainly not the sewing machine smooth sound the Oilhead had when tuned right. That is ok, it just runs and runs and runs...without needing any work like my previous BMW!
