TPMS 2007RT Warning Light
About to go on a 5000 Klm ride in a couple weeks in Australia and the yellow warning icon and light is on and both tires are not registering any pressure. I check my tires on a daily basis when touring, so is there a way to disable the warning till I get back and install some new sensors
- Been liked: 478 times
Re: TPMS 2007RT Warning Light
Found this thread on Adventure Rider, https://advrider.com/f/threads/disable- ... a.1256182/ might be helpful.
Had a look with a GS-911WIFI and it shows pressures on front and rear wheel , battery voltage is ok., but not showing any pressure on dash and yellow warning light still on. Do you think there is a problem with module under the seat
Sorry, it's not something I'm too familiar with, just did a "Google" search to try and help.wilko wrote:Do you think there is a problem with module under the seat.
