Rear-gear oil capacity for 2021 1250RT
wethead
Post by wethead »
Does anyone know where I can find technical documentation from BMW for the rear-gear oil capacity--it is NOT listed on the owner's manual
Levisp
Re: Rear-gear oil capacity for 2021 1250RT
Post by Levisp »
If it is the same as the 1200 LC K52 bike from 2014 then its 180 ml. I cannot believe the final drive is different but do check.
Bevel Gear Oil Change.pdf
(532 KiB) Downloaded 131 times
wethead
Post by wethead »
Levisp wrote: If it is the same as the 1200 LC K52 bike from 2014 then its 180 ml. I cannot believe the final drive is different but do check.
This is in reference to a 1200...I have a 2021 1250RT...lots of folks presume its the same, but I want to get the technical data from a BMW resource specifically for my bike. I find it kind of funky that that information is no where's to be found--so far
Levisp
Post by Levisp »
Sure I understand. I think your only options are to either try and get the latest 1250 BMW workshop manual or ask the tech at your dealer to look it up for you.
krw
Post by krw »
I was only able to find a 2019 manual, which lists 180ml.  I measured what I drained out of my 2021 RT with a mix cup and measured 200ml.
Levisp
Post by Levisp »
krw wrote: I was only able to find a 2019 manual, which lists 180ml.  I measured what I drained out of my 2021 RT with a mix cup and measured 200ml.
When I did my first service back in 2014 I did the same measured out what BMW had put in and was pissed off to see 200 ml. That is incorrect for 1200 bikes it should be 180 ml.
I expect the only manual available for the 1250 bikes is BMW own.
wethead
Post by wethead »
The final work from Beemer land:
200ml for the '21 RT
wethead
Post by wethead »
wethead wrote: The final work from Beemer land:
Then, this is not the final word...ok, I 'll keep looking
Wierpig
Has liked: 5 times
Been liked: 8 times
Post by Wierpig »
The viscosity recommendation has changed as well.From memory its 70/80....
Been liked: 345 times
The Rider's Manual does indeed confirm that the viscosity is now 70W-80, a change from the previous 75W-90.
This spec. sheet agrees with the viscosity and 180 ML capacity, https://www.louis.eu/magazin/rund-ums-b ... /0j61/3753
60Aviator
Bike Model and Year: 2017 GSA & 2021 R1250RT
Has liked: 8 times
Been liked: 12 times
Post by 60Aviator »
Capacity vs Service?
Initial fill 200ml
Service/oil change put 180ml in.
Possible but can't see that changing on 21 RT. No service DVD available for owners yet is really the issue.
