I hit a pothole the other day.....
Old-Git
Post by Old-Git »
just discovered this.....
Has liked: 473 times
Re: I hit a pothole the other day.....
That's a pain! It has been suggested that increasing your front tyre pressure to 38lbs/sq.in may help prevent this, I hope never to find out... but as our fav places to tour are Italy and Greece I suspect I probably will.  :alas:
David and Sally
Has liked: 13 times
Been liked: 16 times
Post by David and Sally »
My son did that on his 1050 Triumph. New wheel😡😡
Our Gee
Been liked: 33 times
Post by Our Gee »
Any chance of a claim against the local authority ?.
Toaster
Bike Model and Year: 2019 BMW R1250RT
Post by Toaster »
No need to buy a new wheel as there is a good chance that damaged wheel can be repaired. I did the same a couple of years ago and the repair I had was almost invisible and cost was in the region of £200 including respray. I would have to search for the name and address of the company that repaired mine, but its near Maidstone , Kent (I think). cheers David
Talisker
Bike Model and Year: R1250RT LE 2020
Been liked: 5 times
Post by Talisker »
Old-Git wrote: just discovered this.....
Testament to the bikes quality suspension that the outcome was not worse.  Last time I did that (a good few years ago) the bike landed on the deck!
Kim_Y
Been liked: 7 times
Post by Kim_Y »
That's a real bummer!! I know because I've had it happen to me.  A new wheel is very expensive, mine actually looked worst than yours and I was able to get it repaired by a wheel repair shop for $150.  After the repair & paint, it looks & functions fine.  My wheel would lose about 3 pounds of air a day.  But definitely it needs to be repaired or replaced.  It's dangerous to continue riding in this condition because the tire bead which is holding the air is now compromised.  I would not want to be traveling at high speeds under these circumstances, a sudden lost of air could be disastrous.
-Kim Y.
Old-Git
Post by Old-Git »
Yep £350 for a second hand wheel, or use Motoliner in Maidstone - Toaster I think that's where you mean.Can't remember where the pothole was, only noticed the damage a few days later, so no chance of suing anybody.And I think Talisker is right, if I had been on my Enfield.....
Our Gee wrote: Any chance of a claim against the local authority ?.
I seem to recollect that they are only liable if they have been notified of the pothole and done nothing about it. I'd love to be wrong...
Our Gee
Post by Our Gee »
I reported a "cluster" of so called Potholes in a dangerous location (on a steep hairpin bend). It took the authority concerned about a week to send someone with a can of white spray paint, presumably to identify the holes to the repair crew. A month later they hadn't been repaired and the paint marking was wearing off. "I give up".
hammo
Been liked: 20 times
Post by hammo »
Do not know about your local council but up in the north east if it caused damage you have to report it and then wait one year to see if the local council took action to repair it if not then you can make roads to claim compensation .
Has liked: 80 times
Been liked: 87 times
Post by Sullivj »
I made a claim against the local council for replacement of 2 wheels on my BMW 330.  I had to prove that the knew about the hole, and had not repaired it in accordance with their own published timescale.
I researched through 'fix my street' and their online reporting tool, to prove that it had been reported and was of a significant depth to have been fixed sooner than they had.
A bit of wrangling later, and they sent my a payment of £630.
Toaster
Post by Toaster »
yes, that's the company....Motorliner....excellent service....
Our Gee
Post by Our Gee »
Just been past the Pothole location today. Success, repairs have been carried out. Now instead of  holes to contend with there are "bumps" but still better than before.
