Posts: 8630 Joined: Fri Nov 07, 2014 7:29 pm
Been liked: 476 times
Post
by David. » Wed Jan 16, 2019 11:14 am
simbo wrote: Will you be using what's left in the bottle in the final drive? Be a shame to see it sat on the shelf for the next 12 months.
Recently purchased some Comma EP80W-90 GL-4 for the XJ650 FD unit, it has a shelf life of 5 years from date of manufacture.
David. on Wed Jan 16, 2019 11:19 am, edited 1 time in total.
Post
by David. » Fri Nov 26, 2021 10:50 am
David. wrote: I use the Castrol Syntrax Longlife 75w-90 (Formerly SAF-XO 75w-90) in the gearbox & final drive.
I see just to confuse matters, Castrol have changed the name and packaging again, Castrol Transmax Axle Long Life 75W-90 (Formerly SAF-XO 75W-90 and Syntrax Longlife 75W-90).
As confirmed by Motorworks,
Motorworks BMW Motorcycle Specialists - Shop - Spares and Accessories
David. on Fri Nov 26, 2021 10:53 am, edited 1 time in total.
Post
by David. » Sun Oct 16, 2022 10:40 am
Have recently been looking for some Castrol Transmax Axle Long Life 75W-90, it's currently out of stock at OPIE Oils, Motorworks and Nippy Normans.
Please can anyone recommend a UK supplier or suggest a suitable alternative, thank you.
Liqui Moly looks like a good alternative,
https://www.infinitymotorcycles.com/pro ... atch%20All
Posts: 1770 Joined: Wed Jun 02, 2021 9:13 pm
Has liked: 619 times
Been liked: 598 times
Post
by Stu » Sun Oct 16, 2022 12:27 pm
I'm not at home at the minute but what's the actual spec that the service manual asks for?
Transmax universal says its for transmissions final drives and differentials and I'm pretty sure that meets the spec so maybe check that one out
Post
by Stu » Sun Oct 16, 2022 3:18 pm
I have dropped Castrol an email to see what they say
I suspect whatever you use as long as it meets the spec it will be more than good enough
Post
by David. » Sun Oct 16, 2022 3:21 pm
sakm wrote: ↑ Sun Oct 16, 2022 3:18 pm I have dropped Castrol an email to see what they say.
It would be interesting to know why Transmax Axle is currently out of stock.
Post
by Stu » Sun Oct 16, 2022 3:23 pm
Maybe there is another replacement we don't know about yet
Post
by David. » Sun Oct 16, 2022 3:25 pm
sakm wrote: ↑ Sun Oct 16, 2022 3:18 pm I suspect whatever you use as long as it meets the spec. it will be more than good enough.
I'm sure you a right but if available, would rather use the BMW recommended Castrol stuff.
Post
by David. » Sun Oct 16, 2022 5:49 pm
This would seem to confirm that Red Line 75W90 meets the BMW SAF-XO spec. too, although more expensive from the USA.
