Brake servos running on
Batfastard
Has liked: 4 times
Post by Batfastard »
Hi. Sorry to be a newbie starting with a question.
Recently bought a 2005 R1200RT after having a break away from bikes for a couple of years. I believe the ABS has been bypassed, I know there is paperwork for it in the folder I got with the bike.
Problem started yesterday. Short run out and noticed what sounds like the brake servo's are running on after releasing the lever/foot brake. Checked levels all ok. Checked and could hear switches operating as should be. Anything else I should check? I would have thought these would have been bypassed along with ABS?
Thanks
Re: Brake servos running on
This video shows the servo and ABS being removed from a 2005 RT, BMW R1200RT IABS3 Servectomy - Whizzy brakes removal - YouTube
Might be worth viewing and comparing with what has been done on your bike.
Batfastard
Has liked: 4 times
Hi David. Thanks for the reply. I have a funny feeling that the ABS has not been removed, despite what i was told, but may have been repaired at some stage. My reasoning being I don't think the ABS can be removed without also removing the servos. The noise i am getting sounds live the servo 'running on' after brakes have been released
Looks like I may have to do it myself  :sueno:
To bypass the ABS unit, the ABS doesn't have to be totally removed. The basics are just a couple of brake light switches, a "U" union, and a longer rear brake line. also a bit of wiring. Why convert to no ABS if the servo sounds to be working?. Have a look on nippy norman site who sells the bypass bits. They also have diagrams of how to fit. Have a look at the front where the pipes join to see if there is a "U" cooper union there. if so it's been bypassed.
Batfastard
Has liked: 4 times
Hi. Problem was the servos sound like they ran on after brakes were released. Unit is out now, just waiting for kit to arrive
