Engine Paint
Our Gee
Been liked: 33 times
Engine Paint
Post by Our Gee »
One of my winter maintenance jobs is to tidy up the lower Crankcase areas where Road Muck and Stone Chips has degraded the finish. Appreciate it if anyone can recommend a suitable paint, preferably in Spray Can format. The original paint would appear to be of a "Satin" type finish. There are lots of what look like similar finish paints available here in the UK such as those recommended for Barbecues, Gas Fire Surrounds etc and it would be nice if anyone has used any of these.
Thanks.
Has liked: 622 times
Re: Engine Paint
The bbq or heat proof paint will dry to a dull like a blackboard type of finish so stay away from those
Has liked: 99 times
Been liked: 228 times
Re: Engine Paint
Hammerite satin Black could be what you're after.
Has liked: 1434 times
Re: Engine Paint
Hammerite smooth satin black is what you're after. It also has good chip resistance
Our Gee
Re: Engine Paint
Post by Our Gee »
Thanks for the suggestions chaps, I'll let you know the results.
Been liked: 477 times
Re: Engine Paint
I bought at 100ml tin of Granville Cylinder Black Satin Finish, it was the only brush on engine paint I could find. Have previously used something called Pot Black but can't remember the manufacturer's name.
Anyway, painted the sump area today from below the bottom of the oil sight glass level on both sides and underneath. The paint is quite thin, goes on and covers easly. Should air dry overnight then cure fully when the engine is running and hot. Pleased with the result so far.
P.S. Does the Hammerite stuff stand up ok to engine temperatures.
Has liked: 99 times
Re: Engine Paint
David. wrote: Sat Dec 03, 2022 6:38 pm
Yes.. But you're more than welcome to google/microsoft edge it, if you don't believe me. :lol:
Re: Engine Paint
"Granville Cylinder Black is a single component, silicone modified alkyd based paint designed specifically for use on surfaces subjected to high operating temperatures."
Has liked: 99 times
Re: Engine Paint
David. wrote: Sat Dec 03, 2022 8:43 pm "Granville Cylinder Black is a single component, silicone modified alkyd based paint designed specifically for use on surfaces subjected to high operating temperatures."
Cool :thumb:
Our Gee
Re: Engine Paint
Post by Our Gee »
I'll let you know in the spring.
Re: Engine Paint
Alkyd paint is tougher than oil based Hammerite.
Re: Engine Paint
simbo wrote: Sat Dec 03, 2022 8:24 pmYou're more than welcome to google/microsoft edge it.
Nah, too technical for me, I'll dig out my set of Encyclopedia Britannica or go to the library like in the good old days.
Re: Engine Paint
Our Gee wrote: Tue Nov 15, 2022 6:55 amThe original paint would appear to be of a "Satin" type finish.
Checked the paint this morning, it's dry but I would say that the "Satin" finish is not the same as the OEM paint which is more "Matt". However, my bike is 10 years old with 43K miles on the clock. Get the panels back on, add some road dirt and it'll all blend in together.
Re: Engine Paint
I have some SIMONIZ Engine Enamel in gloss black arriving today
I have a few pots I want to cover up on my 2016 wethead
I will update on whether this is a good match for the black engine paint
Not sure if it would be the same colour on other models
Has liked: 474 times
Been liked: 405 times
Re: Engine Paint
Here’s the stuff David was referring to, satin black and free delivery too - -
https://www.mandp.co.uk/products/granvi ... 0ml-716282
